It is currently Fri Apr 26, 2019 5:36 am
PostPosted: Wed May 09, 2018 7:33 pm
Year and Trim: 1995 bonneville se L36
Starter only has 2 terminals, battery and purple wire. Purple wire Goes up to throttle or something but that thing is lose and twists easily. Any tips I should try to test starter to save taking off unnessasacryily?
Also the battery ground behind stater is covered in oil, oil pan gasket looks like. The ground to fuse firewall looks good and shiny & ground on fender next to battery looks kinda rusty
My negative terminal is also kind of stripped and can pull out negative with constant rocking. I've overtightned into the soft lead, this proabably not goid. I would some time have wiggle negative to start bc no lights or take bolt out of termianl ans reinstallm
Should i check wiring under front driver side carpet? Heard prone to rust and shortages. But all windows locks work
PostPosted: Wed May 09, 2018 10:25 pm
How to test the starter was described in one of your other threads.
A can of brake clean, some sand paper, dielectric grease and a battery with working terminals would take the first 3 paragraphs of variables off the table.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
There are no new unread posts for this topic. 1995 Bonneville SE Cranks but Won't Start
Roberto
12
2704
Tue Dec 09, 2014 4:05 pm
Roberto View the latest post
There are no new unread posts for this topic. 1995 bonneville wont start and fuel pump relay clicking
zach
Mon Jun 15, 2009 9:50 am
There are no new unread posts for this topic. Car won't start/crank.
Bonnie98ssei
Tue May 24, 2011 12:23 am
Bonnie98ssei View the latest post
There are no new unread posts for this topic. Crank, but won't start
cotubbs
Mon Apr 09, 2012 4:45 am
renchjeep View the latest post
There are no new unread posts for this topic. 94 SSEi No Crank No Start; With Vats Bypassed
Slippy122
Sat Aug 04, 2018 9:26 am
96 SSEi View the latest post
