It is currently Wed Jan 23, 2019 7:52 pm
PostPosted: Mon May 07, 2018 11:57 am
Year and Trim: 1997 SSE
My 97 SSE with 125Km has the FE2 option. The compressor will come on usually once each trip. I notice more compressor cycles when the temps drop, so the strut seals are probably getting brittle and are slowly leaking. The car is sagging in the rear slightly and the exhaust tips have torn off when going up driveways, so the tail is dragging. I suppose the bladders leak over time, but I don't want to bother replacing any of the load leveling gear.
Does anyone make a "lifted" rear strut or a heavy load strut with a coil? I guess a very stiff strut would keep the tail up. The air to coil conversions are too complicated and expensive. Any suggestions?
PostPosted: Mon May 07, 2018 12:52 pm
The cheapest/easiet route is usually to get new air struts.
PostPosted: Mon May 07, 2018 1:48 pm
Thanks. That makes sense. Anyone suggest the stiffest brand of air strut replacement.
PostPosted: Mon May 07, 2018 2:21 pm
Sounds like the best solution. Can anyone recommend the stiffest air strut our there?
PostPosted: Mon May 07, 2018 2:43 pm
I'd recommend Monroe Reflex if they still made them. But they don't. Word is that KYB is the next stiffer option. I have gone from Reflex front struts to KYB and they are pretty similar, maybe a little softer.
There are no new unread posts for this topic. Rear struts
CatmanFS
Wed May 14, 2014 9:59 pm
CatmanFS View the latest post
There are no new unread posts for this topic. Air ride rear struts
ColdScrip
Mon Jul 13, 2009 11:30 pm
1fatcat View the latest post
There are no new unread posts for this topic. Recommendations for rear struts 95SSEi
skregal
Wed Mar 16, 2011 4:38 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Questions on replacing rear air struts
MARGR4V3Z
16
1024
Mon May 19, 2014 2:28 pm
KM AXer View the latest post
There are no new unread posts for this topic. 99 Bonneville (Norm) STRUTS-Rear
Bd1703
Tue Apr 21, 2015 10:20 pm
RJolly87 View the latest post
cron
