It is currently Fri Mar 22, 2019 6:25 am
PostPosted: Wed May 02, 2018 10:17 pm
Year and Trim: 1994 SLE
Recently, when my wife started our '94 Bonneville SLE to leave a grocery store parking lot, the engine speed immediately went to 3500 rpm and stayed there. (This was the case in both Park and Drive with her foot off the gas pedal.)
The engine rpm stayed at 3500 coasting all the way to her 2nd stop, about 1 mile away. When she started the car to leave there, the engine speed was again 3500 rpm in Park (4000 rpm in Neutral). Turning the engine off and restarting it twice made no difference.
No service engine soon light was illuminated throughout this ordeal (though it has illuminated, but intermittently, in the past few months). This is the first occurrence of excessive rpm.
The vehicle has 88,000 miles.
Fortunately, the engine started normally when leaving her 3rd and final stop, and was also fine for the 4 mile trip home.
The engine has not been started since.
Please help. :helpsmilie: Thanks.
PostPosted: Wed May 02, 2018 11:14 pm
I would start with the basics, make sure the throttle is closing properly, linkages are not hanging up, etc.
I would also scan codes. I had a failed TPS that would trip codes some times, but also the issue you are describing as well.
Hopefully you have access to a compatible scanner, as '94 is during the dreaded OBD 1.5 era.
PostPosted: Wed May 02, 2018 11:25 pm
Year and Trim: White 1994 Pontiac Bonneville SE, 3800 Series 1.
Possible Idle Air Control valve sensor (IAC), or Throttle Position Sensor (TPS)
1994 Bonneville SE - Series one. L27
1998 Bonneville SE - Series Two. L36
2001 Bonneville SSEI - Series Two. L67
There are no new unread posts for this topic. rough idle engine
laimisl
14
3915
Mon Sep 26, 2011 8:49 pm
laimisl View the latest post
There are no new unread posts for this topic. Idle in gear problem- Engine goes down to 550 RPM-NEW DATA
azu
20
2334
Fri Mar 26, 2010 2:05 am
azu View the latest post
There are no new unread posts for this topic. Engine Idle RPMs too high, throwing code. Can someone help?
andreyseven
Sun Mar 27, 2011 12:37 am
Bing View the latest post
There are no new unread posts for this topic. P0642 code comes up when coasting
krissondors
Mon Apr 07, 2014 6:54 pm
krissondors View the latest post
There are no new unread posts for this topic. 1994 Olds 88 Royale tranny problem coasting shifting to OD
jphess
Fri Jun 13, 2014 11:02 am
MKMike View the latest post
