It is currently Tue Feb 19, 2019 7:49 pm
PostPosted: Wed May 02, 2018 8:42 am
Year and Trim: 1995 bonneville se L36
My cars CEL has been on intermitingly for over a month I don't have a OBD 1.5 or know anyone with 1. Been Using more fuel. I added 2 cans of seafoam in tank since I've owned 7 -15
Started cranking slow last week new alt and NOV 2014 Batt. Started up and CEL instantly on. Misfiring and running rough, shifting hard drove it around not thinking anything of. Went home backed into curb and bumped kinda hard and moved up, Vame back out, no start. Just a few slow cranks like it has been doing and them after trying a few.times to start, nothing else, no sound.
I can hear thud nder dash and fuel pump him for a few whwn key to ON. All lights are on dash and security light does not blink and goes out. I crank and all warning lights, light up but nothing else no sound. I jumped starter and just sparks. ( i did not turn key or have key in ignition when jumped starter)
I took out all plugs and turned crank and turned and nothing came out of holes. Also rolled it in N and tried to start in N and.in gear nothing. Assuming Starter and or solenoid is now bad but Idk what caused
Also.would dielectric grease on ICM, all over the heat sink and on all 6 coil terminals hurt or help?
PostPosted: Wed May 02, 2018 8:55 am
the grease will act as an insulator so just a thin film is good.
test the battery with a multimeter - probe both posts, +,- , and you should not have a circuit - no tone. if using resistance, you should see infinite resistance
I suspect the battery is funky and cant hold a charge.
borrow a good one for crank test - I remember on my 96, there was a seperate smaller wire running to the maxi fuse on firewall - make sure that one has good connection.
PostPosted: Sun May 06, 2018 8:10 am
I tried to jump mine with jumper cables from another car and no crank nothing still. I need to go get a new voltmeter.
PostPosted: Sun May 06, 2018 8:55 am
I got battery on a 2 amp slow charge. It's analog battery charger but looks like only has 4 volts on it. Gonna charge and re try.
Maybe alternator seized up? It looks kinda rusty behind fan shrouds. I just put that reman 1 on in December. It's under warranty.
PostPosted: Sun May 06, 2018 11:58 am
I got bAttery fully charged and put back in and still no crank or nothing. I turn key and can hear clicks and fuel pump but so turn key back off and to ON again and no sounds.
PostPosted: Sun May 06, 2018 2:12 pm
did you test it with multimeter
PostPosted: Tue May 08, 2018 9:08 am
Volts were 12.39 and 12.39 at starter w key on.
PostPosted: Tue May 08, 2018 9:13 am
look at my first post - test it for continuity between + and - terminal pl.
PostPosted: Tue May 08, 2018 9:18 am
My negative battery terminal is pretty chewed up from overtighning.
PostPosted: Tue May 08, 2018 9:25 am
Remove bolts from terminals and test? Not sure how to test continuity
PostPosted: Tue May 08, 2018 11:10 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Everything you need to know about testing the starter and testing for voltage drop in the circuit here:
http://www.aa1car.com/library/voltage_drop_testing.htm
AND
http://troubleshootmyvehicle.com/gm/3.8 ... er-motor-1
PostPosted: Wed May 09, 2018 1:59 pm
Charged battery to 13.1v and let sit for under an hour an its down to 13.0v. It couldnt be a bad cell could it? Trying to get another side post to try before buying 1.
I did.try to test for amprege 10a and touched leads to terminals and sparked and cranked heard a loud click and nothing else again.
Could motor or bearing be locked up. I turned crank w plugs out but did it in P not N.
There are no new unread posts for this topic. 1995 Bonneville SE Fuel Feed Line Leak
614justin
12
653
Fri Jul 21, 2017 11:45 pm
614justin View the latest post
There are no new unread posts for this topic. 1995 Series 1 Supercharged Lower Intake issues
tripscarcare95
12
2528
Sun Mar 28, 2010 4:35 pm
tripscarcare95 View the latest post
There are no new unread posts for this topic. intake manifold leak with milky oil
withcolt
Fri Feb 27, 2009 11:20 am
bill buttermore View the latest post
There are no new unread posts for this topic. Possible Intake Manifold Leak or Head Gasket
driveway Al
Sat Jul 30, 2011 10:10 am
willwren View the latest post
There are no new unread posts for this topic. Is it a head gasket or intake gasket on a 1995 SE?
Brutus
Fri Mar 30, 2012 6:51 pm
RogueSSEi View the latest post
