It is currently Mon May 20, 2019 6:27 am
PostPosted: Sun Apr 29, 2018 4:09 pm
Year and Trim: 1995 Bonneville SE
2000 Bonneville SLE
Greetings! Out 95 Bonneville SE has pretty bad rust on drivers side cradle outside bushing.... The cradle is fine and the bushing is fine but over half the body metal the bushing/cradle attaches to is gone from rust. Anyone had any luck repairing this problem short of welding in all new metal?
PostPosted: Sun Apr 29, 2018 5:00 pm
That subframe/cradle bolts to the frame so cut and weld is the only option I see other than finding another frame.
PostPosted: Tue May 01, 2018 4:06 am
Year and Trim: 1995 bonneville se L36
Yea I got 4 of the 6 sf bushing kits, with new mounts, washers and bolts. New spacers have to be welded into rusted out mounting holes. Worth it if it's the only rusted part on it. Very reliable motors and automobiles. -Merica 1999
PostPosted: Fri May 04, 2018 9:00 pm
Year and Trim: 1998 Bonneville SLE
Both sides on my car had metal from the body rotting away in that area. The passenger side was very bad to the point where almost the entire corner of the floor was gone. I had to weld new metal in there and pretty much do the entire length along the sides of the floor.
I would recommend checking the floor and rockers if your frame mounting points are going.
There are no new unread posts for this topic. Can I paint the rust spots on my 98 bonneville?????
Ashley.Garrison2012
Mon Jul 23, 2012 12:39 pm
Ashley.Garrison2012 View the latest post
There are no new unread posts for this topic. Source for Engine cradle bolt??
zman
Thu Aug 11, 2011 1:39 pm
zman View the latest post
There are no new unread posts for this topic. 1995 Engine Cradle Dropped
voxetros
Wed Nov 06, 2013 12:36 pm
There are no new unread posts for this topic. 95 Bonneville front end noises
Paintjar
Wed May 08, 2019 3:04 pm
96 SSEi View the latest post
There are no new unread posts for this topic. '97 Bonneville Front Suspension Knock
markr
12
2703
Fri Dec 09, 2011 7:53 pm
willwren View the latest post
