It is currently Wed Jan 23, 2019 8:54 pm
PostPosted: Thu Apr 19, 2018 4:14 am
Year and Trim: 1995 bonneville se L36
CEL has been on and off last few weeks and been grinding pretty hard starting (doesn't usually do this) and was misfiring today, took more gas than usual to get up 2 speed and shifted harder. Took it home and parked it and tried 2 leave later and cranked 1 or twice and clicked, Speedo goes up as long as you hold key.
Was hoping it's not hydrolocked. I've added coolant lately. Gonna remove all 6 plugs and hand crank or turn?
Would a clogged filter cause no start? Filter looks like it's been there a while. Any other suggestions or tricks?
I took out all 6 plugs and tried 2 crank and nothing at all now. I didn't try 2 turn manually. It won't even crank at all, makes no sound when tried 2 start w or without plugs.
PostPosted: Thu Apr 19, 2018 4:26 pm
Took all plugs out and harmonic balancer turns. Could it be starter or crankshaft positions sensor. It wont crank at all but has lights inside and dings anf all that HELP
PostPosted: Thu Apr 19, 2018 7:27 pm
If the starter will not engage even with the spark plugs out, the crankshaft position sensor will not cause that. At worst, it will cause a crank/ no start condition.
You will need to trace out where you are not getting power. Check power at the starter, check all main battery cables, and look for power on the trigger wire on the starter once you have confirmed everything else.
Also, you need to look and see exactly what the security light is doing when you try and start it. If it is blinking continuously or staying on, it could also be the issue. Also, try starting it in neutral with your foot on the brake.
PostPosted: Thu Apr 19, 2018 7:50 pm
I had guy try 2 start. I heard 1 single click outside in front of car you can't hear inside car.
Also Security light goes off after trying 2 start and left in ON. I tried 2 do the relearn thing but the light kept go out so didn't think this would be poblem. I also cleaned MAF sensor w 70% alcohol in spray bottle and alcoholed Vats thing on key.
Gonna try starting in N, was thinking it could be neutral safety switch.
Havent tried 2 jump but volts on dash seem like 12 she thing 2 start, I don't have a voltmeter either.
PostPosted: Thu Apr 19, 2018 7:55 pm
Have put 2 ICMs in and thought it could be that, replaced under warranty and out dielectric grease all over back of it and coil terminals. New alternator this year
PostPosted: Thu Apr 19, 2018 9:08 pm
So I *think* the thread title is saying the car cranks and in the thread it sounds like it's not.
If it's not, try to jump the starter with all the injectors unplugged or fuel pump fuse removed and see if it'll turn over.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Thu Apr 19, 2018 9:30 pm
It cracked once yesterday and now nothing.
I tired 2 start in N and in gear, still nothing.
I removed splash guard so I can get to starter tmrw
PostPosted: Thu Apr 19, 2018 9:31 pm
And what is correct way 2 jump starter?
PostPosted: Fri Apr 20, 2018 11:58 pm
Do it from the top.
Either:
Jump the two terminals with a screw driver that has an insulated handle.
Or
Run a wire of equal thickness or greater to the starter signal wire (smaller of the two going to the starter) from the positive terminal of the battery to the starter signal terminal on the starter.
05 Suzuki DRZ400S
PostPosted: Sat Apr 21, 2018 3:42 pm
Do it from the top? You mean jump terminals on battery? Idt I can get to starter from top of motor
PostPosted: Sat Apr 21, 2018 6:44 pm
When I pop the hood of my 95, I can look down at the starter.
And NO to terminals on the battery.
A starter has 2 terminals. +12 for power and +12 for the starter signal. Turning the key sends the start signal unless something is wrong. If you can jump the starter and it works, you know the starter and wiring from the batter is fine. The problem is associated with the signal.
05 Suzuki DRZ400S
PostPosted: Sun Apr 22, 2018 4:55 pm
I jumped the starter & nothing but sparks. Should I just replace starter or keep going thru fuses or any other tips?
PostPosted: Sun Apr 22, 2018 5:19 pm
Pull the starter, and bench test it.
PostPosted: Sun Apr 22, 2018 10:03 pm
Most auto parts places have a bench tester. So you could pull it, take it to get tested then buy a replacement of it fails.
05 Suzuki DRZ400S
There are no new unread posts for this topic. 1995 Bonneville SE Cranks but Won't Start
Roberto
12
2552
Tue Dec 09, 2014 4:05 pm
Roberto View the latest post
There are no new unread posts for this topic. 98 Bonneville, cranks but no start
andrewisme88
Sat Nov 03, 2012 2:26 pm
andrewisme88 View the latest post
There are no new unread posts for this topic. 95 Bonneville SSE Cranks, no Start. Only 2 injectors pulse.
psiguy
Wed Dec 31, 2014 4:34 pm
MKMike View the latest post
There are no new unread posts for this topic. 99 Bonneville SE stalling at idle or during stop
RR20
12
5220
Fri Jun 10, 2011 6:19 pm
There are no new unread posts for this topic. 1995 Bonneville S SEI M62?
Johnny2521
Mon Jul 22, 2013 12:29 am
J Wikoff View the latest post
