It is currently Sat Apr 20, 2019 8:08 pm
PostPosted: Sat Apr 14, 2018 7:31 pm
Year and Trim: 96 Bonneville SSEi
So I purchased a zZP Downpipe for my 96. Not realizing between 96 and 97 the rear exhaust manifolds changed from the donut style gasket to the flange style. The Downpipe is designed for 97 and newer and does not fit my 96 manifold in any way shape or form. So my next best idea is just out a 97 manifold on it.
I am assuming it will bolt up, but is there any difference in the EGR tubing? Is it just a direct swap?
The car is out of commission waiting for 2 rear shocks as one rear which decided to break in half like they seem to do, and sprung a rad leak on the first fire up after installing my power log and throttle body. Every time I fix one thing, something else goes on this *dang* car. It’s fought me since the day I bought it.
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
PostPosted: Sat Apr 14, 2018 9:19 pm
The rear manifold will be a direct swap.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Apr 15, 2018 9:34 am
Fantastic, looks like I’ll be making a trip to Pick N Pull today. Thanks!
PostPosted: Mon Apr 16, 2018 9:08 pm
Went out to pick n pull on Sunday to get a manifold. Luckily I was able to find a 3.8 from a Grand Prix just laying on the ground totally complete so I snagged the manifold off of it in a matter of minutes. I got home and pulled mine off quite easily while still in the car. The new manifold bolted right up and used the gasket that came with it. However I smacked my trans dipstick tube with the manifold and now the grommet is leaking tranny fluid. Yay, just one more thing to add to the never ending to do list.
PostPosted: Mon Apr 16, 2018 10:59 pm
Lol. I would say it gets easier but it's got wheels, so it doesn't. Expectations sure do get dialed in though.
05 Suzuki DRZ400S
PostPosted: Tue Apr 17, 2018 6:08 pm
If it's got tires or t1ts, it's gonna give you trouble, right? lol
I honestly think the worst job I've done on this car is having to change both the belts. I had a more enjoyable time replacing the water pump lol.
PostPosted: Tue Apr 17, 2018 9:38 pm
Ahahaha. I had to read that 2x.
05 Suzuki DRZ400S
There are no new unread posts for this topic. Exhaust manifold removal and welding
radomirthegreat
Thu Jun 05, 2008 5:13 pm
radomirthegreat View the latest post
There are no new unread posts for this topic. Exhaust manifold gasket question
SUSPECT 0
Sun Feb 13, 2011 2:01 am
swiles View the latest post
There are no new unread posts for this topic. What size stud go to exhaust manifold
Curt
Fri Jul 17, 2015 8:26 am
MKMike View the latest post
There are no new unread posts for this topic. Cracked (Rear) Manifold
nunesjeff
Mon Jan 04, 2010 2:32 pm
willwren View the latest post
There are no new unread posts for this topic. removing rear manifold
1337ssei
21
1531
Mon Sep 29, 2008 7:19 pm
1337ssei View the latest post
cron
