It is currently Sat Jun 23, 2018 9:12 pm
PostPosted: Fri Mar 09, 2018 9:03 pm
Year and Trim: 1995
I've been hearing a clunk, tick, sound from the front passenger side. Not the cv, just went though that on the drivers side, this sound is different and happens mostly on take off. Checked the tie end rod,its intact, checked the spring for cracks, it seems fine. I looked around the forum for similar issues,best guess is a looses mounting bolt. Tightened the one on that side, the one you have to take out for belt replacement and one on the drivers side, but still see the engine move around when I shake the car back n forth. Where are the rest of the bolts I need to try? I can't find a diagram, not in the Chiltons, no luck online. And where are the subframe bolts? I read those can rust out. And the other idea was oiling the top of the spring assembly, what kind of oil and where do I apply it? Any advice is very appreciated.
PostPosted: Sat Mar 10, 2018 11:21 am
hi, with hood open so you can see the engine, start the car and closely inspect with a flashlight while a helper puts it in gear - you will see excessive movement. you look for movement of engine- a slight separation from the frame. look all around the engine, left and right - also check the trans mount that is near the rad on right.
do this and tell us your issue - look carefully at the mount you messed with - it may not be correct torque.
PostPosted: Sat Mar 10, 2018 11:43 am
Year and Trim: 1997 SSEI 40th
Check stabilizer bar links. they can rust thru and can still look intact.
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, SD Headers, MagnaFlow Cat 94109, Catco catback, Autolite 104s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
PostPosted: Sat Mar 10, 2018 7:33 pm
Year and Trim: 1995
What is the correct torque for the mounting bolts? And you're saying there is a bolt under the right side of the radiator?
I will check the stabilizer links and bushings.
Thank you.
PostPosted: Sat Mar 10, 2018 7:52 pm
Year and Trim: 1995
Checked the links, no play, bushings are solid.
The engine is wiggling on the back side, drivers side. I looked straight down from the brake reservoir and see a bolt, but it seems small for a mounting bolt. I'll have to get it up and look from underneath, but how many bolts am I looking for?
PostPosted: Tue Mar 13, 2018 1:04 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re the subframe: It's not usually a case of the nolts rusting out.
Typically it's the the subframe bushing holes which rust out--in some cases actually allowing the rear of the subframe to drop.
If the holes around the 4 rear bushings rust out, you need a subframe replacement or welded repair.
1992/topic36156.html
This shows the driver's side of the subframe
95naSTA wrote:
Nope:
PostPosted: Tue Mar 13, 2018 1:59 pm
Find the dogbone shaped trans mount under the rear of the trans on the passenger side. I bet it's loose or broken.
PostPosted: Sat Mar 17, 2018 9:20 pm
Year and Trim: 1995
Ok, I will check those subframe bushings and the mount. Thank you very much.
PostPosted: Fri Apr 13, 2018 10:36 pm
Year and Trim: 1994 White on white SSE
If it is a small popping sound perhaps it's the strut mount bearing. I am dealing with that right now on my 1994 SSE, 160,XXX miles.
There are no new unread posts for this topic. Clunking sound?
Dopey85
Fri Jun 18, 2010 12:29 am
wjcollier07 View the latest post
There are no new unread posts for this topic. Which Axle for '93 SLE HD 3:06 passenger's side?
MKMike
Fri Apr 15, 2016 6:15 pm
MKMike View the latest post
There are no new unread posts for this topic. Heat warmer on passenger side
burger
Tue Nov 29, 2016 6:15 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Passenger Side Headlight Housing Bracket
duke81
Sun Sep 12, 2010 6:32 pm
tripscarcare95 View the latest post
There are no new unread posts for this topic. how to access passenger side relay/fuse panel
Billha
Sun Apr 05, 2009 8:24 pm
92BonnevilleSE View the latest post
