It is currently Mon Jan 21, 2019 4:10 pm
 Post subject: Change to supercharged?
PostPosted: Fri Mar 09, 2018 8:39 pm
Year and Trim: 1995
Hello. I have a 1995, non supercharged model,now over 200k miles and the opportunity to buy a supercharged model engine. How difficult a replacement is this?
PostPosted: Thu Mar 15, 2018 11:45 pm
Year and Trim: 96 Bonneville SSEi
Good news. Just talked to gmtuners and they have compatible software that will work, so I’m going to give it a try and see how it works out!
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
PostPosted: Fri Apr 13, 2018 10:42 pm
Year and Trim: 1994 White on white SSE
Compatible software for 1995 model? For tuning? That is good news.
To answer the OP question, anything is possible with enough time and money. To keep it as simple as possible, swapping the driveline from the same model year will provide the fewest headaches. You would need the wiring and PCM etc too...
There are no new unread posts for this topic. Change accessory serpentine belt on Supercharged engine L67
blye
Thu Mar 28, 2013 11:14 pm
Focke-Wulf190 View the latest post
There are no new unread posts for this topic. 93 SSE supercharged won't run
94SilverSSEi
Sun Jul 26, 2009 12:27 am
There are no new unread posts for this topic. please help a newbie with a 99 sle(not supercharged)
snewman34
18
1714
Mon Feb 13, 2012 12:06 pm
There are no new unread posts for this topic. supercharged 3.8 from an 03 grand am for my 99 SLE
g2barbour
34
1944
Thu Apr 17, 2014 8:51 pm
g2barbour View the latest post
There are no new unread posts for this topic. Car Jerking 96' SE Supercharged
Dcastillo13
Fri Aug 12, 2016 6:17 pm
Jrs3800 View the latest post
Users browsing this forum: No registered users and 14 guests
