It is currently Sun Feb 17, 2019 10:23 am
 Post subject: Correct key fob?
PostPosted: Sun Jan 21, 2018 2:35 pm
Year and Trim: 96 Bonneville SSEi
Both my my '96 cars do not have key fobs.
I tried a key fob from roughly '98 or so, the typical black round style ones, and could not get it to program on either car after having the car in the programming mode with pins 4 and 8.
I then tried an early-mid 90s square style fob from an Oldsmobile and it would not program either. I had brand new batteries in both fobs.
What is the correct fob to have for a 1996 and is there any special steps other than jumping pins 4 and 8 and having it enter the programming mode? I watched how to videos and waited more than 30 seconds every time I held the lock and unlock buttons and seemed like neither remote would respond.
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
 Post subject: Re: Correct key fob?
PostPosted: Sun Jan 21, 2018 4:35 pm
Try googling for the FCC id numbers that will work with 96. I know they switched them up from time to time.
PostPosted: Sun Jan 21, 2018 6:31 pm
Will do. Thank you for all your fast replies!
PostPosted: Sat Jan 27, 2018 12:55 pm
I was on Rock Auto looking up key fobs and for 96 they show the black newer style rounded one like I have now. However it says on there that 96-99 Bonnevilles and a few other models need dealer programming while a few other cars could do the programming yourself such as Aleros.
Am I doing the programming correctly like I described in the original post?
PostPosted: Sat Jan 27, 2018 1:59 pm
I thought 96-99 could do it at home.
PostPosted: Sat Jan 27, 2018 7:11 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
JWikoff is right.
I've done the fob programming on my 98 as described here:
http://www.programyourremote.com/classi ... -6187.aspx
The most important info is listed on the item page
SE Model; REMOTE ENTRY LK CONT(AU0)
Which means that, if your SE doesn't have the Keyless Entry Package, listed as AU0 on the spare tire cover label, then the fobs will not work.
I don't know which year Pontiac began including keyless entry as standard equipment, rather than an option, but I've seen it listed as an option for 1996 SE..
PostPosted: Sat Jan 27, 2018 8:08 pm
I ran the vin decoder on gm forum and i could not or did not see keyless remote entry on the options list for my car but everything else was correct. So maybe I do not have AU0.
PostPosted: Sun Jan 28, 2018 3:06 am
contact the dealer and ask - should give info free...
PostPosted: Sun Jan 28, 2018 12:55 pm
1998 SE
2001 SSEI
2002 SSEI
...or just look at the label on the plastic cover for your spare tire.
The RPO code label with all of the equipment codes is found in the trunk on the spare tire cover of Bonnevilles, under the carpet.
PostPosted: Sun Jan 28, 2018 2:55 pm
As I mentioned my RPO sticker is missing, this is why I asked.
PostPosted: Mon Jan 29, 2018 1:13 am
1998 SE
2001 SSEI
2002 SSEI
You didn't mention it in this thread. That's why I suggested looking at the sticker.
PostPosted: Mon Jan 29, 2018 2:04 am
Oh my bad. I mean, that would have been the obvious place to look. However it shows my car has power locks and Pass Key but nothing about remote entry.
PostPosted: Tue Jan 30, 2018 2:02 pm
yes, my 96 SSEi had only key entry - no remote
PostPosted: Wed Jan 31, 2018 8:49 pm
Well that's lame. My car had an aftermarket remote starter at one time but I did not get the remote with the car when I bought it.
I feel like such a peasant with a poverty spec SSEi LOL
PostPosted: Wed Feb 14, 2018 11:27 am
The 96 SSEi had keyless as standard equipment, The 96 SE is a tad different.. If the 96 had option group 1SB keyless was an option, if it was option group 1SC or 1SD it was standard.
PostPosted: Sun Feb 25, 2018 7:59 am
I should check on my SE and see if I can program it. My RPO code sheet is also missing in that car.
However I have had no luck on getting the SSEi to program and I have tried with several remotes. I'll try the SE today and report back.
There are no new unread posts for this topic. edit:was -correct torque for LIM/UIM - now conflict answers
mhobryan
Mon Dec 31, 2012 9:38 am
mhobryan View the latest post
There are no new unread posts for this topic. Correct cold start idle speed for a 1996 Bonneville SE
SSEBonne4evr
Sun Aug 03, 2014 8:08 pm
