It is currently Thu Feb 21, 2019 1:31 pm
PostPosted: Sun Jan 21, 2018 1:32 pm
Year and Trim: 96 Bonneville SSEi
I have a 96 SSEi and 96 SE. Both cars are showing manfunctions in the air suspension systems, most likely from the struts being worn out and leaking. Both compressors work fine but are unplugged right now.
Is there an OE or aftermarket option for converting these cars to standard gas struts, from say a base model or another related car? My local parts store couldn't come up with any findings other than air strut replacements. I had an '02 LeSabre before I bought my Bonnevilles and there was a rear strut/coilover conversion I was able to get from Monroe to replace the auto level system in the rear.
Thanks!
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
PostPosted: Sun Jan 21, 2018 4:37 pm
You'd need non-air struts and springs. It's probably cheaper and easier to get new air struts.
PostPosted: Mon Jan 22, 2018 8:30 pm
I would just have to change the rear springs to stiffer ones while I could then replace the rear shocks with standard gas ones and standard gas macpherson struts up front?
I don't mind going back to OE air struts, but if I could get rid of it sounded like it would be a cheaper and less complicated way to go. I suppose the most common failiure of the air suspension system is the struts leaking? My compressor would run forever and nothing would happen and both lights on the console were lit up. Obviously this indicates a leak somewhere in the system. I can see all 4 of the air struts are leaking oil and the boots look very cracked and worn looking.
PostPosted: Mon Jan 22, 2018 11:27 pm
If your compressor is working, I'd get air struts. I've got Monroe's that have lasted nearly 100,000 miles and hold air just fine.
PostPosted: Wed Jan 24, 2018 8:57 am
Probably the route I'll go. I mean, it's only money and if I keep going to work there's only more of that where it came from, right? Lol
There are no new unread posts for this topic. Convert to center console shift?
92BonnevilleSE
Tue Nov 17, 2009 8:51 pm
Bugsi View the latest post
There are no new unread posts for this topic. 98 SSEi suspension problems
CatmanFS
Fri Mar 21, 2014 8:41 pm
There are no new unread posts for this topic. 99 ssei suspension issues
biggbonnie
Mon Apr 02, 2012 11:10 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. ssei suspension and brake questions.
motopsyco
Tue Feb 17, 2015 12:42 am
95naSTA View the latest post
There are no new unread posts for this topic. 1999 SSEi suspension issue
blye
Fri Apr 12, 2013 5:24 am
impala67 View the latest post
