It is currently Mon Feb 18, 2019 2:01 pm
PostPosted: Tue Jan 16, 2018 10:05 am
Year and Trim: 1994 Bonneville SE
1994 Bonneville, 3800.
Severe overheating issues. After replacing radiator,thermostat, UIM and LIM gaskets with no help in overheating, decided to pull the head cylinders to check gaskets. Lo and behold, 90% of the water ports in the head gaskets were completely clogged.
So now I'm wondering if I should give the cylinder heads a good scrubbing and pop them back on, or have the cylinder heads rebuilt (i.e. valve job- something I don't want to do myself), or simply purchase rebuilt heads for around $250 each.
She's got 200K miles on her. And I plan on using her as my DD for at least another 50K miles. Any recommendations?
PostPosted: Tue Jan 16, 2018 10:30 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Overheating an engine can lead to cracked heads. The point where they tend to crack is the narrow spot between the valves. Use a fine wire wheel to clean the metal there until it's shiney and you can see if they are cracked. Might need a magnifying glass and flashlight to see any cracks.
If they are not cracked, you should be OK with a good cleaning and reinstall.
Runs:
Doesn't run:
PostPosted: Tue Jan 16, 2018 11:28 pm
You can heat any suspect areas with a torch to see if oil bubbles out of the potential crack.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
There are no new unread posts for this topic. Heads Up & Car Monitor
ernie44golf
Sun Jan 15, 2012 5:21 pm
willwren View the latest post
This topic is locked, you cannot edit posts or make further replies. Heads Up & DIC & Gauges on right
ernie44golf
Wed Jan 18, 2012 1:23 pm
There are no new unread posts for this topic. Cylinder 4 Misfire?!?
94SilverSSEi
Mon May 02, 2011 10:51 pm
There are no new unread posts for this topic. Missing a Cylinder.
SammyZ
Tue Dec 09, 2008 2:44 pm
bobfather99 View the latest post
There are no new unread posts for this topic. cylinder 3 misfire
forcefedbucket96
Sat Jun 30, 2012 9:38 am
Bing View the latest post
Users browsing this forum: Google [Bot] and 16 guests
