It is currently Mon Jan 21, 2019 1:40 pm
 Post subject: Difficult Steering
PostPosted: Tue Dec 26, 2017 1:01 pm
Year and Trim: 1996 Oldsmobile 88 LS
3.8 NA
Parking lot steering has gotten difficult lately. This is my daughter's car (1996 Olds 88 with 201k miles) so it needs to get fixed. I checked the fluid and it was nasty, so I replaced what's in the reservoir with fresh fluid a couple times, but it hasn't helped. Has anybody had this issue? Any ideas what might be the most likely culprit? Am I looking at a new pump (hopefully it's not the rack and pinion)? Is there a reliable way to test it to make sure that's what's wrong? How big of a job is it to replace it? About how much would it be to have someone else do it? Thanks in advance.
3.8 NA
 Post subject: Re: Difficult Steering
PostPosted: Tue Dec 26, 2017 10:54 pm
How hard is the steering? Still somewhat assisted, but still feels as it should at speeds above 20mph? Hard all around? Was this a gradual change or sudden?
PostPosted: Wed Dec 27, 2017 11:46 am
3.8 NA
I would say still somewhat assisted and feels okay above 20 mph. The change has been gradual. FYI - serpentine belt was replaced not long ago.
3.8 NA
PostPosted: Wed Dec 27, 2017 8:27 pm
I'll have to look at my FSM to confirm the details, but my Park Avenue is configured with a baseline power steering level, and then there is a solenoid that kicks in below 17mph that gives additional assistance for low speed maneuvering that is controlled by the chime module. It's GM's variant of variable effort power steering so to speak. I can't recall how hard the steering is without the extra boost, but it does make a difference, especially when I feel it kick in during a curve while slowing down.
Has anything else cropped up recently?
PostPosted: Wed Dec 27, 2017 10:00 pm
3.8 NA
I don't know if mine has the additional solenoid - not sure how to check that.
The last thing I had to do (other than maintenance) was a coolant elbow and the serpentine belt.
3.8 NA
PostPosted: Sat Jan 27, 2018 10:06 pm
3.8 NA
I've been driving the car and it's not related to speed (under 20 mph) as much as it is revs. I'm continuing to get complaints from family members that have driven it and nobody wants to drive it any more. I think I'll check the belt tensioner to make sure it's okay and try jacking up the front wheels and try steering left to right, back and forth without the engine running. That should tell me if it's something other than the pump. Then maybe I'll try having somebody else steer it while the engine is running to see if I hear or see anything unusual.
3.8 NA
PostPosted: Sat Feb 17, 2018 10:50 pm
3.8 NA
I jacked the front of the car up and steered the wheels back and forth both with the engine running and without. There is a distinct clicking noise under both conditions that you don't hear when you drive the car. It's not just one or two clicks, but a series of evenly spaced clicks as you turn it. I hope that doesn't mean I need a new rack. :sad:
3.8 NA
PostPosted: Sat Feb 17, 2018 11:28 pm
Check the intermediate steering shaft (the bit before the rack). That is exactly how many would describe an ISS failure on a later generation.
There are no new unread posts for this topic. Power steering difficult to turn to left at idle/slow sped.
reb
Sat May 12, 2012 4:46 pm
Roadtech195 View the latest post
There are no new unread posts for this topic. How difficult wheel bearing?
imidazol97
Tue Aug 05, 2008 6:36 pm
Ol' Timer View the latest post
There are no new unread posts for this topic. Difficult P0300, looking for more ideas
zuper8
27
2492
Tue Mar 17, 2015 10:55 pm
There are no new unread posts for this topic. Brass freeze plugs.. are they really this difficult?
eazhar
Mon Jan 21, 2013 12:57 am
eazhar View the latest post
There are no new unread posts for this topic. Drum Brakes Change On This Gen. Bonneville Difficult?
GotBonneBWitMe
14
1533
Mon Sep 23, 2013 9:30 pm
Tim's Buick View the latest post
