It is currently Fri Jan 18, 2019 5:36 pm
 Post subject: Back seat removal
PostPosted: Fri Dec 22, 2017 7:14 pm
Year and Trim: 1998 Bonneville SLE
Anyone know how to remove the back seat in a 98? I've got the part that you sit on out but not sure how to take out the back part.
 Post subject: Re: Back seat removal
PostPosted: Fri Dec 22, 2017 8:17 pm
I think it's a few bolts that hold it in along the bottom, then it lifts off a couple hooks hiding on the back.
PostPosted: Fri Dec 22, 2017 10:18 pm
Taking out the bottom gives access to the nuts holding the seat back in place. Once these are removed, the seat back slides up and off.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Jan 21, 2018 2:38 pm
Year and Trim: 96 Bonneville SSEi
Once those bottom bolts are removed and the seat slides up and out. If you're removing the rear seat to access the speaker shelf, it should pull out once a couple of push pins are removed. From there you'll have access to the speakers as they are bolted in from the top but wired in from the bottom. Access to the 3rd brake light is from below the shelf inside the trunk.
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
There are no new unread posts for this topic. Front/Passenger Seat Removal - Torx Bit Size?
RegencyRoyale
Sat Jul 25, 2009 3:31 pm
There are no new unread posts for this topic. Removing back seat
92BonnevilleSE
Sat Apr 04, 2009 10:11 pm
92BonnevilleSE View the latest post
There are no new unread posts for this topic. Removing back seat and inserting a bed.
ianzea
14
2071
Mon Jul 29, 2013 3:54 pm
Bugsi View the latest post
There are no new unread posts for this topic. Driver's seat wont tilt back down
Boreas
Tue Jul 22, 2008 1:14 am
Boreas View the latest post
There are no new unread posts for this topic. Driver's side seat - reclines too far back - 95 ssei
pappyl
Thu May 28, 2009 12:55 pm
pappyl View the latest post
