It is currently Wed Feb 20, 2019 9:02 am
PostPosted: Thu Dec 21, 2017 9:14 pm
Year and Trim: 1995 bonneville se L36
Any tips on why it would not be spraying wiper fluid?
I have summer fluid in there I need to get it out asap if I can't get it spraying again?
Wipers still work just not spraying fluid
PostPosted: Thu Dec 21, 2017 11:03 pm
DO YOU HEAR THE MOTOR WORK WHEN YOU USE it? - get a tube and siphon out the fluid or add -35c fluid straight - if it stays above -10c, it wont freeze in bottle
you can follow the rubber hoses from each wiper to the bottle - look for breaks - mine got disconnected somehow.
PostPosted: Fri Dec 22, 2017 1:50 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Just add a generous amount of rubbing alcohol to it, so it doesn't freeze up.
Details here:
https://www.wikihow.com/Make-Windshield-Washer-Fluid
Make sure the fuse hasn't burned out.
The nozzles can clog and the washer motor can burn out eventually
PostPosted: Wed Dec 27, 2017 9:44 pm
Year and Trim: 1996 Oldsmobile 88 LS
3.8 NA
You might try removing the nozzles and soaking them in water and white vinegar 2 to 1 for a couple hours. Then clean the passageway with compressed air etc. I tried that on one of my cars and it worked well. Also check all the hoses that run to the nozzles.
3.8 NA
There are no new unread posts for this topic. windshield wipers died
pmicaza
Fri Jul 23, 2010 1:59 pm
pmicaza View the latest post
There are no new unread posts for this topic. Windshield wiper fluid tank and rubber tube
clarkhamblen
Wed Oct 08, 2008 11:41 pm
clarkhamblen View the latest post
There are no new unread posts for this topic. Windshield Washer Fluid Light/Sensor Module
jonnevilleSSEi
Wed Dec 29, 2010 10:22 pm
jonnevilleSSEi View the latest post
There are no new unread posts for this topic. wipers wont shut off 1996 bonneville
ad356
Tue Mar 04, 2014 8:47 pm
ad356 View the latest post
There are no new unread posts for this topic. 98' bonneville se. NEED WINDSHIELD
wpbrink
Sat Jan 24, 2015 7:05 am
wpbrink View the latest post
