It is currently Mon Jan 21, 2019 1:44 pm
 Post subject: Supercharger question
PostPosted: Sat Dec 02, 2017 7:46 am
Year and Trim: 95 ssei
Hello, I own a 95 ssei. Been getting code 0640 on my actron 9145 (qdm#1 fault). Did a live data check and it showed boost at 100% at idle. Is this normal? I took the boost solenoid off and checked resistance. It came in at 195 ohms. I read where it should be between 500k and 1.5 m. So do I need a new boost solenoid? Thanks!
PostPosted: Sat Dec 02, 2017 12:09 pm
Sounds like you need a new one. A series one BCS will be hard to find, but a series 2 BCS will work.
PostPosted: Sat Dec 02, 2017 12:28 pm
Thanks! I read where the series 2 will work if you bend the bracket a little..buying one today!
There are no new unread posts for this topic. Supercharger question
Sacaledus
12
1710
Wed Jun 09, 2010 3:44 pm
Billha View the latest post
There are no new unread posts for this topic. how much supercharger oil do i need?
haro1225
Mon Jan 11, 2010 1:41 pm
This topic is locked, you cannot edit posts or make further replies. SUPERCHARGER
bobates
Sun Sep 05, 2010 12:26 pm
willwren View the latest post
There are no new unread posts for this topic. is it the supercharger?
bonnelover
Fri Feb 25, 2011 6:16 pm
bonnelover View the latest post
failure
Thu Feb 07, 2013 6:57 pm
failure View the latest post
Users browsing this forum: Exabot [Bot] and 7 guests
cron
