It is currently Fri Apr 10, 2020 5:25 am
PostPosted: Fri Dec 01, 2017 2:50 pm
Year and Trim: 95 Pontiac Bonneville
HELP!!!! I am gonna cry!!! we bought a 95 Bonneville & the transmission went in it within a month! never even put the plates on it!! So we bought a damaged 94 Bonneville, that we took the transmission out of & its at the shop right now... we just noticed that the key tag says 92 and double checked the door, yep it's a 92!! I'm afraid this guy totally screwed us!! Can anyone tell me if a 92 is compatible with a 95???
thanks
PostPosted: Fri Dec 01, 2017 3:44 pm
Supercharged or naturally aspirated?
PostPosted: Sat Dec 02, 2017 1:14 am
yes, I believe it will be if the trim matches, the supercharged engines need a different one than the lower models. the tranny place would have told you already if it wont work.
PostPosted: Sat Dec 02, 2017 10:22 pm
...might be tricky, the 95 model year was a one year only for a lot of things with OBD1.5 in the mix. I know that you have to put a 95 transmission in a 95 Chevy Astro.
PostPosted: Mon Dec 04, 2017 12:15 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
http://www.gmtuners.com/tech/440_4T60E_4T65E.htm
I don't believe you can just drop a '92 trans into a '95. It will mount in and bolt down fine, but there were slight differences in the controls internally. I think the main difference would be the torque converter apply strategy (extra solenoid on the 95) which is not compatible. I don't know if the harness is different. It might bolt in and plug in fine, but you would have issues and a check engine light for the TCC, and reduced gas mileage.
PostPosted: Sat Dec 09, 2017 12:59 pm
Both the 92 and 95 Bonneville 4T60E use the PWM strategy... But they are wired differently internally... I really wouldn't go backwards from 94- 95 to 92, but I would go forward like 96 and or 97 as the 4T60E was improved for those years.. the 94-97 4T60E for the H body is wired the same.. 92-93 is wired differently..
There are no new unread posts for this topic. Transmission
PLAGUE PHANTOM
32
4354
Thu Mar 08, 2012 5:48 am
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. transmission
lilpon
Tue Jul 10, 2012 4:25 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. transmission on its way out?? o.O
douellette88
Sat Jul 16, 2011 9:18 pm
There are no new unread posts for this topic. '98 SE Transmission
jrl87
Wed Sep 05, 2012 11:34 am
There are no new unread posts for this topic. bad transmission
xvr843
Tue Apr 19, 2011 1:58 pm
willwren View the latest post
