It is currently Wed Jan 23, 2019 12:09 am
PostPosted: Tue Oct 24, 2017 1:17 am
Year and Trim: 95 SSEI
OK. We had to rebuild the engine. Got it running but now when it idles or are at a stoplight we lose oil pressure but at normal driving its normal.
We are also having trouble with it constantly saying that its overheating even right as we start it.
Could it just be our gauges?
PostPosted: Tue Oct 24, 2017 10:42 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Might be wiring, a sensor, unlikely just the gauge as those shouldn't have been touched during the engine R&R.
The oil pressure one might be annoying to fix. Rebuilt engines usually hold ~10psi/1000rpm. So at idle, 8-9 psi is all you get. I think the factory gauge/sensor setup cuts off at 10psi before it starts chiming and showing no oil pressure. But check it with a mechanical gauge first to know for sure what the oil pressure is, and get a new 'quality' replacement part if the sender doesn't match what the mechanical gauge tells you.
Runs:
Doesn't run:
PostPosted: Thu Nov 16, 2017 4:38 pm
Year and Trim: 1998 Bonneville SE
Try replacing the pressure sensor. It went bad on my '98 and was leaking oil. Should fix it.
1998 Pontiac Bonneville SE with XM Radio, Heated Seats and more! (Retired)
2009 Chevrolet Impala LTZ (Daily Driver)
There are no new unread posts for this topic. oil pressure drop after 5K on Mobil 1
Larry Larson
Fri Mar 28, 2014 2:14 pm
There are no new unread posts for this topic. oil pressure drop when close to oil change time...
Larry Larson
20
2597
Sat Feb 25, 2012 9:59 pm
Larry Larson View the latest post
There are no new unread posts for this topic. 1995 SSEi No Oil Pressure
madtech
12
1671
Tue May 14, 2013 6:32 pm
madtech View the latest post
There are no new unread posts for this topic. Part # for oil pressure switch? (96 SSEi)
Boreas
Sat Sep 06, 2008 3:43 pm
Pontiac1 View the latest post
There are no new unread posts for this topic. 96 ssei oil pressure falls as engine temp rises
tan96ssei
27
3241
Thu Jul 02, 2009 2:57 am
FiltranZer View the latest post
