It is currently Thu Jan 17, 2019 5:39 am
PostPosted: Fri Apr 28, 2017 11:26 am
Year and Trim: 1997 SSEI 40th
Looking to replace all 4 corners. Have heard good things about KYB Excel-G shocks on other cars. I see they are now available for the
1997 Bonneville. These are pretty pricey $450.00 complete set. Are they worth the difference? I do like a performance ride. Anybody have opinions on this shock??
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, SD Headers, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
PostPosted: Fri Apr 28, 2017 11:59 am
I put a set on the front of my 92 when I thought a shimmy it had could be coming from the 80k mile old Monroe Reflex struts (stiffer than stock, not made anymore). I got a slight improvement in ride. They come with and without springs/mounts. I might suggest getting the bare struts and reusing your springs. My front end did go up a bit. I haven't put 500 miles on it since then in the last few years, so maybe it'll settle down, idk.
PostPosted: Fri Apr 28, 2017 12:40 pm
Thanks for reply. What about the mounting components, Should I replace them as well? Definately going with KYB excel-G fronts. What about the backs? I have ELC with a hole in baffle.
PostPosted: Fri Apr 28, 2017 3:10 pm
Definately get mounts/bearings. If you get the sets with springs, they'll be all the parts you need. I don't recall who offers what for the rear.
PostPosted: Fri Apr 28, 2017 7:35 pm
I like the complete package deal (Strut/Spring) but are my OEM springs better/stiffer? I do not want the front end any higher than it is now. Is that the main reason to keep my old springs?
PostPosted: Sat Apr 29, 2017 12:00 am
Year and Trim: 96 SSEi- 157K
I have also heard that the OEM springs are better quality than the ones included on quick struts. I am old fashioned and disassemble the old strut and re-use. Careful use of the spring tool and a Hail Mary have kept me from getting a spring to the face yet. I put KYB struts and mounts in my 96 SSEi a year ago, I am very happy with the smooth ride, and better handling. I prefer these over the Monroes I used to buy.
- Rachael
PostPosted: Sun Apr 30, 2017 12:46 am
I have used Monroe twice on a '92 Bonneville. I would not use Monroe again. - BC
PostPosted: Thu May 11, 2017 10:42 pm
I put these on my front - http://www.rockauto.com/en/moreinfo.php ... 94&jsn=259
and Gabriel self leveling shocks on the rear in the last year. I really just bought the Gabriels because they were a manufacturers closeout and a good deal. I've never had a good experience with Monroe and unfortunately there's not many choices for '97 Bonnevilles. I'm pretty happy with the KYB ride but it's by no means a 'performance ride' like a European sports sedan. I guess the shock manufacturers model the shocks after the OEM specs and that's just what you get. But I would stay away from Monroe for sure.
PostPosted: Fri May 12, 2017 7:07 pm
Thanks for replies. Going to order the excel-G shocks. Has anyone added the rubber spring stiffeners, that go between the coils of the spring. I seem to remember an old thread but could find it. Any thought?
PostPosted: Mon May 22, 2017 7:45 pm
Ordered the rear shocks first and a new air line kit and top mount. we let you know how I like them.
PostPosted: Sun Dec 03, 2017 9:04 pm
Hey, Finally got around to replacing front struts and Rear shocks. So far I love the KYB Excel-G's. Car handles much better, less under-steer. Back to a firm ride with less roll in corners. Still pretty new (500 miles) but I'm very pleased.
There are no new unread posts for this topic. Added KYB Excel -G shocks, One question.
Pair of SSEI
Sun Jun 04, 2017 1:59 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. Kyb Excel-G vs. Monroe Sensa-Trac - Parts are coming!
Jfridge92
52
6299
Sun Aug 30, 2015 9:18 pm
There are no new unread posts for this topic. Air shock pressure?
trf_ssei
Tue Mar 17, 2009 12:34 am
There are no new unread posts for this topic. setting up a gas shock system
spoiledred94
Sat Oct 23, 2010 11:59 pm
There are no new unread posts for this topic. Rear shock and alignment
krummelt1
Mon Oct 18, 2010 9:29 pm
