It is currently Tue Sep 22, 2020 2:28 pm
PostPosted: Wed Jan 04, 2017 9:24 pm
Year and Trim: 1989 Oldsmobile 88 Royale Brougham Regency - FE3
I'm looking at a 95 LSS with the supercharged engine. Owner thinks its a head gasket issue, car starts and idles fine but when engine is over 1500 rpm it has a knocking sound. Any idea what this could be?
1989 Oldsmobile 88 Royale Brougham Regency - Grey on Grey - FE3 - X06 Package - Limo Tint - Clarion HU - 2K Pontiac Grand Am 15" Alloy Rims
PostPosted: Wed Jan 04, 2017 11:59 pm
A head gasket wouldn't knock. It would be something like a rod bearing.
PostPosted: Thu Jan 05, 2017 12:52 am
Searched a bit and some suggested it could be a flex plate, Harmonic balancer, or coupler inside the nose cone. Someone also suggested to unhook the supercharger belt and see if its still there.
PostPosted: Thu Jan 05, 2017 10:58 am
Yeah, try taking the SC belt off, and the other belt too. Run it just long enough to see if the noise changes both ways. I once had a belt that had a tear in it that made the tensioner jump and it made it seem like the engine had a knock.
Can you get video?
PostPosted: Fri Jan 13, 2017 1:42 am
Can you get video?
Haven't had a chance to get a video.
Can you drive the car with the supercharger belt off?
PostPosted: Fri Jan 13, 2017 2:39 am
I meant in park. But a Series 2 can run without the SC belt because there isn't anything else on that belt. A series 1 shares that belt with the water pump and should not be run without it for more than a minute, and only in park.
There are no new unread posts for this topic. 1995 Bonneville spark knock in OD
rustyoldcars
Wed May 04, 2011 2:35 pm
95naSTA View the latest post
There are no new unread posts for this topic. 1997 Oldsmobile 88 Engine Issues
94SilverSSEi
19
3210
Thu Aug 25, 2011 10:59 am
There are no new unread posts for this topic. Coolant loss question for 1995 SE 3.8L non supercharged
Brutus
Sat Mar 24, 2012 9:09 am
Brutus View the latest post
There are no new unread posts for this topic. HELP! 1995 SSEi Supercharged - Coolant Gauge Bouncing Around
Farmer1989
11
285
Fri Aug 21, 2020 8:52 pm
Farmer1989 View the latest post
There are no new unread posts for this topic. 1995 Series 1 Supercharged Lower Intake issues
tripscarcare95
12
3062
Sun Mar 28, 2010 4:35 pm
tripscarcare95 View the latest post
