It is currently Mon Feb 18, 2019 2:08 pm
PostPosted: Wed Dec 21, 2016 6:08 pm
Year and Trim: 1993 SSE
Member since Nov 2003
How much of the dash has to come apart? Just spent a day fiberglassing cracks and broken tabs in my door panel and don't want to dig into the dash if it will be another storm of old fragile plastic tabs. Only looking to fix the dead spots in the dash dimmer so should i leave it be?
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
PostPosted: Wed Dec 21, 2016 6:56 pm
Take the dash panel off, then the panel above the gauge cluster, IIRC. I did mine a couple years ago and didn't break anything. I don't remember taking too much caution either.
PostPosted: Wed Dec 21, 2016 10:52 pm
Year and Trim: 95 SSEi
05 GXP
i've replaced mine like 4 times now. I can do it blindfolded.
Main clipped-on front panel has to be popped off. Bezel around
the switch and top panel over the cluster. I believe they
are torx screws. It takes alot of wiggling to get the switch
out of the hole but it will eventually come out.
The only real risk is popping the clips on the front panel, which
could break.
Black 95 SSEi (original owner) 236K miles
Black 05 GXP (some idiot put the first 12K on it)165K miles
Black 04 Tahoe (original owner)284K miles
Black 16 Traverse (original owner)48K miles
Black 15 Lacrosse (some nice lady put first 15K on it)16K miles
PostPosted: Mon Dec 26, 2016 9:45 pm
could break.
When you say front panel, are you talking about the fascia that covers the vents, HVAC, radio, and gain slider? If so i'm good there.
Thanks! My interior plastics have turned into a house of cards. Maybe from too much armorall.
2011 Camaro 2SS
PostPosted: Thu Dec 28, 2017 12:55 pm
I waited to long to do this. The switch for auto headlamps is no longer available. Can the switch for manual headlights be piggybacked on to the back of my automatic part of the switch?
2011 Camaro 2SS
PostPosted: Thu Dec 28, 2017 11:17 pm
I wondered that same thing when I was doing it. I don't remember the conclusion I came to.
PostPosted: Fri Dec 29, 2017 10:56 am
Ordered one, i'll report back.
2011 Camaro 2SS
PostPosted: Thu Jan 04, 2018 4:36 pm
Yep the Standard Motor Products DS656 switch screws right on the back of the twilight sentinel part. No need to find the discontinued DS657. Check out the filings and/or corrosion on my old dimmer.
I wanted to remove the cluster and clean the connections for my intermittent DIC, but couldn't get enough wire pulled out to disconnect the cluster. The plastic is all so fragile.
2011 Camaro 2SS
PostPosted: Thu Jan 04, 2018 5:16 pm
Excellent. Good find!
PostPosted: Thu Jan 04, 2018 11:05 pm
Year and Trim: 99 Bonneville
kool nice job
90 SSE Bonneville Sold but not forgotten.
PostPosted: Fri Jan 05, 2018 3:25 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Thanks for posting your result.
Surely it will help others.
I appreciate the good clear pics, too.
There are no new unread posts for this topic. headlight switch
xvr843
Wed Dec 28, 2011 2:55 am
impala67 View the latest post
There are no new unread posts for this topic. Headlight switch connector
rr1105
Sun Jan 23, 2011 1:36 am
There are no new unread posts for this topic. headlight switch broken!!!
jmans8000
Mon Jun 24, 2013 9:36 pm
There are no new unread posts for this topic. Headlight switch wiring
superman013
Sun Aug 28, 2011 9:12 pm
human View the latest post
There are no new unread posts for this topic. Headlight Switch Frustration
3800SERIESII
Sat Oct 19, 2013 10:00 am
