It is currently Sun Feb 17, 2019 9:22 am
PostPosted: Mon Nov 07, 2016 5:31 am
Year and Trim: 1998 pontiac bonneville se
Does anybody know if I have 4 brake lines or 3 with the back brakes combining into 1
PostPosted: Mon Nov 07, 2016 8:49 am
It should be 4 channel abs. So, 4 lines. It might be two that run from the master cylinder to the abs unit, then 4 from there to the brakes.
PostPosted: Mon Nov 07, 2016 9:42 am
hi, from the abs controller there will be 1 line going to each wheel - if you get it off the ground, you can trace the lines to the respective wheel.
PostPosted: Tue Nov 22, 2016 2:29 am
A couple of questions :
1. When I flare the brake line should I use
a double flare or bubble flare?
2. Depending on a double or bubble flare
what size fittings do I need to buy?
PostPosted: Tue Nov 22, 2016 9:50 am
you will need a flare - and union to match flare
the bubble wont fit flare fitting and lines
PostPosted: Tue Nov 22, 2016 1:46 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
There are two sizes of brake line used on these cars, 3/16" and 6mm (can use 1/4" to replace).
These are from the '97 that I did a few years ago.
Front Brake hardware
Brake line to brake hose: M10x1.0 (3/16 line) BLF-39C-5
Brake line to ABS: M12x1.0 (3/16" line) BLF-48C-5
Master cylinder to ABS: M12x1.0 (1/4" line, all 4 same) NAPA 641-3329
Rear Brake hardware
Brake line to ABS: M10x1.0 (3/16" line)
Brake line to Proportioning valve: M12x1.0 (inlet) M10x1.0 (outlet) (3/16" line)
You need to bubble flare anything that's going into the factory connections, all brake line connections from the factory are metric and bubble flare.
If you have to add a splice, it doesn't matter if you bubble flare or double flare, as long as it matches the union you use. The fittings will work with either flare style.
Runs:
Doesn't run:
PostPosted: Tue Nov 22, 2016 2:30 pm
[quote=
[/quote]
i find this strange.both my ssei(96,2000) and 92 gtp had flare to fittings.
PostPosted: Tue Nov 22, 2016 7:32 pm
'05 STS-4
'97 LeSabre
Yep. Basically everything FWD GM with a unibody uses all metric hardware. I'm sure there are limited exceptions to that rule, but everything on the '92-'99 H-body is definitely metric with bubble flares from the factory.
Now, I've seen people jamb a double flare in a bubble flare socket...But you risk stripping the hardware getting it tight enough to seal.
Runs:
Doesn't run:
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE-- BRAKE line size??
wpbrink
Tue Oct 11, 2016 6:45 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE-- BRAKE line shop manual request
wpbrink
Mon Nov 07, 2016 5:28 am
wpbrink View the latest post
There are no new unread posts for this topic. 1998 Pontiac Bonneville Car is not working right
Ashley.Garrison2012
19
1919
Thu Jul 19, 2012 2:04 pm
There are no new unread posts for this topic. 1998 Bonneville Brake Warning Light Problems!
98_SLE
Wed Nov 10, 2010 6:00 pm
There are no new unread posts for this topic. twilight sentinel photocell ??? 1998 Pontiac Bonneville
wpbrink
Tue Mar 27, 2018 9:30 pm
93celicaconv View the latest post
Users browsing this forum: Exabot [Bot] and 6 guests
