It is currently Tue Apr 16, 2024 2:32 am
 Post subject: 1995 SE
PostPosted: Thu Sep 08, 2016 5:41 pm
Year and Trim: 1995 bonneville se L36
I need to replace the 4 subframe body mount bushings on 95 bonne se. The front 2 near bumper seem good and compressed still. Can i do this with jack and stands or should i pay a shop 200-250 labor? I have basic tool, i do have torque wrench. I found 4 new bushing kits w hardware and free shipping 180. There like 70 a piece at local store. Also ive seen alot of color coded bushing combo and differnet hardwares. Should i get oem?
 Post subject: Re: 1995 SE
PostPosted: Thu Sep 08, 2016 7:27 pm
hi, yes you can raise car and use jackstand for car - then use jack to support and lower subframe
can be done if you have the proper jacks....good luck
PostPosted: Thu Sep 08, 2016 9:01 pm
What do you mean proper stands? 2 ton?
Do i need to get an engine hoist?
PostPosted: Thu Sep 08, 2016 10:53 pm
Year and Trim: 2001 SSEi
No engine hoist needed. Jack up car, then put jack stands under car, then use the jack to support the sub frame. Loosen bolts a little and lower the sub frame a little. Go slow and don't lower farther than you need to to get the bushings out. I'd work on one side at a time. I'd spray the snot out of everything with PB Blaster a couple of times starting a day ahead of time to allow it to penetrate so it'll be an easier job. loosen the opposite side to allow the side you're working on to be able to move down enough.
You've got this man!
PostPosted: Fri Sep 09, 2016 7:12 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Be aware that very often the problem is that the subframe itself has rotted, due to the effects of winter road salting.
When this happens the holes becomes too large and then the subframe can drop down, as the bushings are no longer supporting the frame.
The holes are supposed to be form fitted to the bushing, not round.
This thread has pics http://www.pontiacbonnevilleclub.com/forum/post458871.html?hilit=subframe#p458871
There are no new unread posts for this topic. 1995 SE L36
614justin
Mon Dec 12, 2016 5:32 pm
MKMike View the latest post
There are no new unread posts for this topic. 1995 L36 Wheel hub
614justin
Mon Feb 20, 2017 10:13 am
95naSTA View the latest post
There are no new unread posts for this topic. Changes between 1994-1995?
danseaview
Wed Oct 10, 2012 10:34 am
Irving216 View the latest post
There are no new unread posts for this topic. 1995 Bonneville S SEI M62?
Johnny2521
Mon Jul 22, 2013 12:29 am
J Wikoff View the latest post
There are no new unread posts for this topic. TDM location 1995
xcbullet
Tue Nov 08, 2011 7:54 am
