It is currently Mon Feb 18, 2019 3:10 pm
PostPosted: Thu Sep 01, 2016 10:53 pm
Year and Trim: 1995 Bonneville SE
2000 Bonneville SLE
Greetings! I purchased the following rebuilt a/c compressor via Amazon. My mechanic installed it tonight and said the a/c compressor won't engage and he doesn't know why. He did say the back of the a/c unit is a bit different that the stock one taken out mechanic say there is an extra wire coming out of the back of the a/c unit with no where to plug it in. Did I purchase the wrong a/c compressor? thoughts? Amazon still shows it fits a 95' Bonneville.
RYC Remanufactured A/C Compressor Oldsmobile 88 V6 3.8L 3800cc 231cid 1995-1995 10306220
by R&Y A/C Compressors
Be the first to review this item
Price: $114.99 & FREE Shipping
You can earn $3.44 in 3% back rewards with the Amazon.com Rewards Visa Card. Learn more
In Stock.
Estimated Delivery Date: Wednesday, Sept. 7 when you choose Two-Day Shipping at checkout.
Ships from and sold by R & Y A/C COMPRESSORS INC..
PostPosted: Fri Sep 02, 2016 9:37 am
hi, how is the refrigerant level: comp. wont engage if its too low
you can always contact the seller for tech support
PostPosted: Fri Sep 02, 2016 7:40 pm
Do you have a picture of this?
There are 2 pressure switches, one for low side at the Accumulator/Drier... And the high will be on the back of the compressor.. Most times the high pressure switch will have to be installed in the rear of the compressor.. When you turn on the AC the signal goes through these 2 switches and then back to the PCM.. If one or both are disconnected the compressor will not engage.
PostPosted: Sun Sep 04, 2016 2:10 pm
Year and Trim: 2001 SSEi
I'm searching this item and looking at pictures of it and I don't see any wire coming out of the back of it. It shows having a plug close to the clutch, but no other wires. I would guess that you ordered correctly, but they shipped the wrong item. If you go to Amazon and look at pictures of the item you purchased, does it look like what you got? Again, Google "ryc 10306220" and the item you will get doesn't show having a wire coming out of the back of it. I think you got shipped an incorrect part. I think your mechanic should have noticed this before he installed it. I hope he doesn't make you pay twice once you get the correct part.
PostPosted: Fri Sep 09, 2016 7:34 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
It appears that your 95 is one that used the HD6 compressor.
http://www.rockauto.com/en/catalog/pontiac,1995,bonneville,3.8l+v6,1247509,heat+&+air+conditioning,a/c+compressor,6628
Look at the pics of the HD6 compressors--some brands like ACDelco you can view the backs.
Rockauto offers forum members a 5% discount when you use the code found in their post on the Pontiac Bonneville Club Vendor's forum
There are no new unread posts for this topic. 1995 Bonneville S SEI M62?
Johnny2521
Mon Jul 22, 2013 12:29 am
J Wikoff View the latest post
There are no new unread posts for this topic. Transmission does not engage
spoiledred94
21
3570
Fri May 29, 2009 1:49 am
There are no new unread posts for this topic. 1995 Pontiac Bonneville SE
614justin
Tue Feb 06, 2018 6:10 am
Bugsi View the latest post
There are no new unread posts for this topic. 1995 Bonneville SE Not starting
StephanieDP3
Sat Aug 25, 2012 7:47 pm
StephanieDP3 View the latest post
There are no new unread posts for this topic. 1995 bonneville se brakes? or hub?
614justin
Tue Aug 09, 2016 8:42 pm
MKMike View the latest post
