It is currently Tue Jan 22, 2019 4:37 am
PostPosted: Sat Aug 06, 2016 3:59 pm
Year and Trim: 1995 bonneville se L36
How do replace an ICM on 95 L36?
Do i just remove ignition coils?
Do i need di electric grease?
PostPosted: Sat Aug 06, 2016 5:55 pm
Yeah, remove the coils, and the screw in the middle of the wires on the harness that holds it on. Some dielectric grease on the contacts won't hurt.
PostPosted: Sat Aug 06, 2016 7:02 pm
It's a good idea to hit the aluminum the ICM mounts to with a wire brush, then put a very liberal amount of di-electric grease on the heat sink/ground. As well as a normal amount on the coil towers, and connector as mentioned above.
yourgrandma wrote:
High
PostPosted: Sat Aug 06, 2016 10:48 pm
Thanks. This a great site and service. Pure Americana, even if its made in Canada.
There are no new unread posts for this topic. 1995 Pontiac Bonneville SE
614justin
Tue Feb 06, 2018 6:10 am
Bugsi View the latest post
There are no new unread posts for this topic. ***** 1995 Pontiac Bonneville 3800 II help needed *****
MeLLoCeLLo
28
4895
Fri Apr 29, 2011 11:54 am
MeLLoCeLLo View the latest post
There are no new unread posts for this topic. 1995 Pontiac BonneVille Mechanical Issues
jahmal804
Fri Jan 04, 2013 1:52 pm
jahmal804 View the latest post
There are no new unread posts for this topic. 1995 pontiac bonneville, loss of power smell of gas HELP
Watchmasters
Thu May 23, 2013 8:39 pm
DaMaroon View the latest post
There are no new unread posts for this topic. Help. my high beams dont work 1995 pontiac bonneville
Watchmasters
Sat Jul 13, 2013 12:29 am
motopsyco View the latest post
Users browsing this forum: Exabot [Bot] and 7 guests
