It is currently Mon Feb 18, 2019 12:04 pm
PostPosted: Fri Apr 10, 2015 11:11 pm
Year and Trim: 1995 SSEI
Hey guys, i just bought a mint 95 SSEi and didnt realize until I got it home, that the sensor works, but when the headlights turn on the dashlights go off. I can hear the module click when the headlights turn on then I have no dash lights. Obviously I tried turning the switch on the dash to no avail. Doing a little digging here in the forum i see that maybe I should try with replacing the switch? Does that make sense? Or could it possibly be the module under the dash that is the issue? Any help would be greatly appreciated!
PostPosted: Sun Apr 12, 2015 8:23 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
The first thing I would check is to see whether or not the taillights are illuminating.
It is actually a safety feature that, when your taillights aren't working, your dashboard lights turn off to alert you to the taillight failure.
If they aren't working, then check and change the fuse and/or bulbs and see if the problem resolves.
Let us know the outcome.
PostPosted: Sat Apr 18, 2015 10:18 am
I checked and I do have taillights. Of course I've checked all the fuses and everything seems fine.
PostPosted: Sun Apr 19, 2015 3:03 am
Our headlight switches control a lot of lighting functions and are not failproof. When mine went bad the headlights would randomly turn off. In your case I think the portion that controls the dash brightness probably went bad.
PostPosted: Mon Apr 20, 2015 1:20 am
Ok I'll start with replacing the switch. Where's the best place/link to buy one? Thanks!
PostPosted: Mon Apr 20, 2015 1:57 am
New ones are kinda expensive. Maybe get a junkyard unit to try?
PostPosted: Mon Apr 20, 2015 9:48 am
I replaced the headlight switch on my 92 SSE quite a while back. It wasn't cheap, but I wanted dash lights. - BC
There are no new unread posts for this topic. 1992 SSEi turns over slow
redmetrix
Sun Jul 23, 2017 5:57 pm
redmetrix View the latest post
There are no new unread posts for this topic. 1995 TPS Sensor work in a 1993?
1993SSEi
Wed Dec 02, 2009 9:35 am
1993SSEi View the latest post
There are no new unread posts for this topic. 1995 SSEi ABS Issue
ktownSSEiguy
Tue Nov 24, 2009 4:33 pm
ktownSSEiguy View the latest post
There are no new unread posts for this topic. 1995 SSEI Transmission
Rustinc
11
4582
Sun Jan 31, 2010 6:08 pm
willwren View the latest post
There are no new unread posts for this topic. 1995 SSEi No Oil Pressure
madtech
12
1687
Tue May 14, 2013 6:32 pm
madtech View the latest post
Users browsing this forum: Exabot [Bot] and 15 guests
