It is currently Thu Feb 21, 2019 9:26 am
PostPosted: Tue Jan 20, 2015 9:36 pm
Year and Trim: 1998 se
I recently replaced the blower motor and resistor and now my heater continues to run when the car is shut off what can cause this because even when heater is off it pulls on battery causing it to go dead
PostPosted: Tue Jan 27, 2015 9:39 am
Year and Trim: 1993 SSE
Member since Nov 2003
Was it a new resistor or junkyard part?
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
PostPosted: Tue Jan 27, 2015 1:37 pm
Year and Trim: 2004 GTO
More than likely the resistor, happend to me one time. I found myself unplugging the blower motor every time I left the car for a while.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Tue Jan 27, 2015 4:46 pm
Year and Trim: 96 SE
if you have the ECC i have also had same problem. in my case i pulled fuse from panel located over resistor (sometimes referred as BLOWER MOTOR CONTROL MODULE).
PostPosted: Tue Feb 03, 2015 1:40 pm
Year and Trim: 1997 Pontiac Bonneville SSEi
By any chance, do you have the electronic leveling control? If so try pulling the maxi fuse for the ELC under the dash and see if that fixes your problem
I had this EXACT same problem last year, and it turned out to be a shorted out air pump behind the rear passenger wheel. A hole had been sand blasted right through the motor casing because of the absolutely ridiculous location it was put.
Alternatively, start pulling maxi-fuses one by and until you isolate which circuit is causing your short, but I'm willing to be it's your ELC if equipped.
PostPosted: Tue Feb 03, 2015 7:30 pm
You have ECC (electronic climate control) confused with ELC (electronic level control). The OP is having an issue where the heat is not turning off. Not the suspension.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Tue Feb 03, 2015 10:18 pm
to help isolate problem, pull fuse F3 (3rd from left), 30 amp, located in the MAXIFUSE/RELAY PANEL midway the firewall under the hood. the blower motor should stop.
There are no new unread posts for this topic. Heater Blower constantly runs after turning ignition off
WiTurkeyHunter
Mon Jan 18, 2016 10:11 am
WiTurkeyHunter View the latest post
There are no new unread posts for this topic. Car runs great, when it runs...possible security system prob
hobbie2k
24
5174
Sat Feb 04, 2012 4:14 am
There are no new unread posts for this topic. cooling fan runs constantly
dray420
Wed Apr 06, 2011 10:41 pm
willwren View the latest post
There are no new unread posts for this topic. 95 sse, no idle. runs from 1500rpm and up.
bulldodger78
Wed Jul 06, 2011 9:33 am
J Wikoff View the latest post
There are no new unread posts for this topic. Air ride compressor - runs no compression - how to fix?
Cooey
Mon Jun 23, 2008 10:19 am
93RedSled-SSE View the latest post
