It is currently Mon Apr 15, 2024 11:57 pm
PostPosted: Mon Jul 07, 2014 10:04 pm
Year and Trim: 1994 Bonneville; NOT super-charged; likely SSE
For my 1994 Bonneville SE:
2 years ago I used Dorman #800-153 (3/8" diameter steel tube with compression fitting) and a tube-bender to near-exact replace the rusted-thru high-pressure fuel-line coming out of the filter ... this worked well.
Now, the parallel Return fuel-line (same location, under the P.S. rear door) is rusted-thru (sometimes I can smell fumes), and, it looks like this Return-line steel tube diameter is a bit smaller than the 3/8" high-pressure line.
Can anyone confirm that the steel Return-line is 5/16" (under the P.S. rear door) ?
If the steel Return-line is 5/16" then I am thinking about using Dorman #800-154 (intending to cut-off 1 end of the beaded ends) to fit into the O.E. nylon quick-disconnect towards the rear (into the sender unit), along with Dorman #800-142 compression fittings for 5/16" tube diameter to splice into the OE steel Return-line that runs from the front.
Thanks for any info.
PostPosted: Mon Jul 07, 2014 10:40 pm
My Series 1 L67 equipped 95 had a 5/16" return. I would have to assume they wouldn't use any other size on your 94.
PostPosted: Mon Jul 07, 2014 10:50 pm
Year and Trim: '99 Montana
'92 Trofeo
:withstupid:
5/16 return line was used on all of the '85-'99 C/H-body cars I've seen.
PostPosted: Tue Jul 08, 2014 9:17 am
Thanks for the quick accurate info ... I am now going to order the Dorman parts #800-154 and #800-142.
PostPosted: Sat Jul 19, 2014 5:16 pm
OK, before confirming the source of the gasoline odor I ordered the Dorman parts ... yes, as described the fuel return-line parallel to the fuel filter is severely rusted.
Today I get the P.S. rear up in the air and crawl under to confirm the fuel odor location.
Turns out I find an ~ 3/8" length-wise split in the the rubber-connector for the other not-rusted line (the smallest-diameter vapor line) between the metal vapor line (from the front) into the nylon tube (going to the rear) next to the fuel filter.
With the engine running, when I put my finger over the split in the rubber connector, then no fuel odor.
This vapor line rubber-connector looks to be 2-diameter molded ... a bit wider on the nylon tube end than on the metal line end.
I have some sizes of typical vacuum hose,
but instead of trying to use a single diameter vacuum hose as a replacement
I am thinking of wiping some Permatex Form-A-Gasket#1 into that OE rubber-connector split.
Anyone have a better idea, or a part# for the 2-diameter molded rubber connector ?
There are no new unread posts for this topic. Return Fuel Line Damaged need gearhead help please
1oldman
14
3534
Fri Dec 02, 2011 12:38 am
There are no new unread posts for this topic. Pressure (p.s.i.) in the Fuel Return Line of Series II 3800?
StraTact
Sat Apr 07, 2018 11:55 am
StraTact View the latest post
There are no new unread posts for this topic. Brake line diameter?
alec_b
Fri Nov 20, 2009 1:34 pm
J Wikoff View the latest post
There are no new unread posts for this topic. Fuel line question
Blownville
Tue Oct 13, 2009 10:38 am
Blownville View the latest post
There are no new unread posts for this topic. 1995 Bonneville SE Fuel Feed Line Leak
614justin
12
1379
Fri Jul 21, 2017 11:45 pm
614justin View the latest post
