It is currently Fri Apr 10, 2020 5:30 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Wed Apr 23, 2014 6:33 pm
I need some advice to try and troubleshoot my daughters Bonne.
She finally replaced the battery so now it attempts to run but stalls a few seconds after starting.
The SSEi had been having this problem before the winter and it was getting progressively worse, so she parked it and drove her Escape. The Ford is in way worse shape.....no surprise. She says the Ford wobbles and she has to add steering fluid constantly....
So she tried disconnecting the MAF but no effect, still stalls. She can smell unburnt fuel so it appears to be getting fuel.
The plugs were replaced. The TPS & O2 sensor are not that old. The ICM was replaced as well as the PCM.
It had been throwing an EGR code last year but we ignored it. The EGR was replaced with a Bonnevilles Unlimited used unit when I had the car. I can't think of anything that hasn't been replaced. Original fuel pump. No cat.
Maybe some other control module...??
:helpsmilie:
2000 SSEi - SilverBullet - 78,000 kms, 4" "straight shot" custom headlight ram air inlet, TOGs, 1.9's, Lsd, 2.9-3.4"MPS 10-15 psi, Ported GenV, EGR eliminated, OR pushrods, oil volume kit, trani cooler & shift kit, Titanium retainers, 90 lb springs, 160 Stat, 42# injectors, Fuel pump voltage increase, Wideband O2, 3" to dual 2 1/2" Magnaflows, Snow Meth/water injection, after SC temp gauge, 255/50WR17, timing commander set 15-18*@WOT, 2 speed Fan over-ride, disabled DRL, Solid motor mount, Meziere Electric water pump, adjustable fuel pressure regulator, Drilled & slotted rotors/ceramics, GXP sway bars and STB, Upgraded and rebuilt transmission, Pioneer Bluetooth stereo with sub and 800 W amps, PB 13.5 quarter, (April 2014 car of the month)
PostPosted: Wed Apr 23, 2014 6:37 pm
I'm trying to troubleshoot over the phone long distance......I can hear it fire up right away, run for 3 seconds and then die.
PostPosted: Wed Apr 23, 2014 6:44 pm
When she was using it as a DD it would intermittently stall when she took her foot off the gas.
The IAC has not been changed.....hmmm.....could this be the culprit?
PostPosted: Wed Apr 23, 2014 8:45 pm
Not sure Paul...
That 3 seconds sounds a lot like a security issue... From the factory the fuel enable circuit is set to 4 seconds... so if it does start it will dies in 4 seconds if there is a security problem..
But the stalling while driving is odd... If she feathers the throttle while starting it will it continue to run? If it does then it may very well be an IAC issue.. But you'd need to see the live data to know whats going on..
PostPosted: Wed Apr 23, 2014 9:02 pm
Because she smells fuel when it dies, I thought this may be more indicative of not getting enough air.
I asked her to try what you suggested so we'll see what happens.....
PostPosted: Wed Apr 23, 2014 9:07 pm
If it's a security issue, what can cause it?
PostPosted: Wed Apr 23, 2014 10:59 pm
Maybe the IAC needs cleaning. Could be worth a shot.
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Wed Apr 23, 2014 11:24 pm
She tried it again and gave it some throttle but it died just the same.
So what can be done about a security issue? Will she have to get it towed to a dealer to Tech 2 it?
:helpsmilie:
PostPosted: Thu Apr 24, 2014 8:57 am
I thought (at least on 99s) that security issues wouldn't even let the car start? It almost sounds like what mine did when my maf went bad. It would crank and fire, and then die right away, even with the maf unplugged. They swapped a new maf on and it worked. If she has access or can try a spare maf, it might be worth it. I remembered mine smelling super rich too when it would die.
Also, when it dies, does it act like she just turns the key off, or does it stutter and act like it's dying before it does? My maf acted like I just turned the key off.
Joseph
1999 Infiniti G20T - Sold
PostPosted: Thu Apr 24, 2014 3:46 pm
I found her a used MAF for $60. She will replace it and see if that solves the problem.
I see another person has a similar problem with his 01 so I subscribed to his topic....
PostPosted: Thu Apr 24, 2014 8:58 pm
:bwoohoo:
:banana:
The Grizz lives again!!
....and she did it while holding her 2 month old!
:hail: Thanks for your help guys.
PostPosted: Thu Apr 24, 2014 10:17 pm
Glad to hear it's back up and running Paul! Did the maf wind up doing the trick?
Joseph
PostPosted: Thu Apr 24, 2014 10:41 pm
PostPosted: Fri Apr 25, 2014 12:29 am
Yay for reliability once more! Glad it was an easy and relatively inexpensive fix.
PostPosted: Fri Apr 25, 2014 4:38 pm
LOL it pissed off her husband who was insulted that she did it.........and didn't have time to make his dinner when he got home from work.
"That's my work! Yours is in the kitchen with the babies"
Ya right, that's why the car has been sitting idle the last 6 months.
She had to replace the battery just to get it started....again all while nursing my grandson!
You can imagine how proud she was to have done it herself.
The feeling of satisfaction, as we all know, is priceless.
PostPosted: Fri Apr 25, 2014 11:47 pm
I always encourage the daughters and grand-daughters to learn all they can about everything, especially cars. I told them I do not want them to have to depend on a man (or a woman). Sounds like the son-in-law needs to get a new program. I've had one or two like that too. Glad your daughter can take care of herself and the grand-children. - BC
PostPosted: Sat Apr 26, 2014 8:45 am
I was raises with the mentality that the woman shouldn't ever do work like that, but now that I'm older and with my wife who likes to do things herself and not be coddled, I like that way a lot better. I would want my daughter to know how to get herself out of a pinch if she needed to. That's why if I have a daughter, she'll be outside under the car with me learning. :btruestory:
Joseph
PostPosted: Sun Apr 27, 2014 6:53 pm
She just texted and said it still has difficulty starting. It will stall and then after a couple of starts and stalls it will keep running.
I told her to take it into the dealer for a scan and diagnosis for $75. :banghead:
PostPosted: Tue Apr 29, 2014 8:05 pm
It doesn't even kick a code. Tho I did notice the temp screen came on with turning signal. It's a black screen unless the turning signal is on. It's electrical. That's like...impossible to figure out
PostPosted: Tue Apr 29, 2014 8:36 pm
Year and Trim: 00 Regal
You know Paul.. after Don says something like maf/iac. Likely his next suggestion is pcm. Do you happen to have a spare?
97 Ei
97 GS
98 GS
There are no new unread posts for this topic. Grizz gets a Dog Bone
2000Silverbullet
20
2463
Thu Mar 19, 2009 12:05 pm
willwren View the latest post
There are no new unread posts for this topic. Grinding Grizz!
2000Silverbullet
65
3924
Fri Sep 12, 2008 11:41 pm
There are no new unread posts for this topic. Earth Child - AKA Grizz
2000Silverbullet
35
2920
Fri Jul 08, 2011 11:59 am
There are no new unread posts for this topic. Grizz code troubleshooting
2000Silverbullet
Tue Oct 11, 2011 1:59 pm
There are no new unread posts for this topic. The Grizz busts another gut! - finally fixed :)
2000Silverbullet
17
1662
Tue Jun 08, 2010 12:52 pm
