It is currently Tue Apr 16, 2024 12:47 am
PostPosted: Mon Apr 21, 2014 2:33 pm
Year and Trim: SE 1993
Hi there, I own a 1993 Bonneville SE and this is my first post here. I've been having a strange problem with the engine for a while. The ignition starts fine and then the engine operates within the 1500-1700 rpm. When I accelerate (engine still cold), it kind of chokes (with muffled backfire-ish sounds...) and won't go past 2500 rpm. After a longer drive this is no longer an issue, everything works nice and smooth. I've replaced the fuel filter recently but it didn't help and I'm running out of ideas.
I'll be grateful if someone can give me a hint/suggestion how to sort it out. Thanks!
PostPosted: Mon Apr 21, 2014 2:55 pm
Could be the throttle position sensor. Any codes?
When cold the engine is in closed loop running enrichment mode.....possibly fuel related.
PostPosted: Mon Apr 21, 2014 9:13 pm
I also wonder if the MAF is to blame. If you unplug the MAF, does the issue get better or worse?
PostPosted: Tue Apr 22, 2014 10:42 am
Thanks for your suggestions 2000Silverbullet and RJolly87. The engine service soon isn't flashing so I can't read any codes. I haven't tried unplugging the MAF yet.
Today it got even worse, I could hardly start the engine. Then I noticed some red oil underneath but it's hard to figure where it's leaking from...
PostPosted: Tue Apr 22, 2014 11:46 am
Year and Trim: 2006 Saab 9-3 SportCombi
Red oil is transmission oil. I'd try to get under there and find out where it is leaking from. Depending on where it is leaking from could help solve your problem
-Mike
-17x8 OZ Racing Superleggera wheels- -GReddy Exhaust- -K&N Panel filter- Tinted Windows- -Blacked out side markers-
Tune coming soon
2000 Bonneville SLE - Totalled
There are no new unread posts for this topic. what does normal temp reach in 1996SSEI
lisa83
Mon May 26, 2008 3:15 am
lisa83 View the latest post
There are no new unread posts for this topic. oil pressure higher than normal
Billha
16
4420
Wed Oct 08, 2008 2:15 am
bonnevillain View the latest post
There are no new unread posts for this topic. Pull Engine or Drop Tranny to Replace Rear Engine Seal?
gtrichter
Sat Feb 01, 2014 9:15 pm
There are no new unread posts for this topic. series I engine leaks & repairs (engine oil cooler hoses)
aukc
Sun Apr 30, 2017 8:16 pm
PavliCZek View the latest post
There are no new unread posts for this topic. Engine rebuild or Crate engine
94SilverSSEi
12
3360
Wed Jan 06, 2010 3:44 pm
chris c View the latest post
