It is currently Tue Sep 25, 2018 11:04 am
PostPosted: Thu Jan 30, 2014 10:18 am
Since installing my projectors, the lamp monitor keeps saying headlight out. Since the HIDs only take signal from some side. How can I trick the monitor into thinking there isn't a bulb out, without affecting the function of the lamp monitor otherwise? I took apart a 9006 bulb and soldered the filaments together, my logic being that the bulb had a resistance of 0 ohms, and plugged it into the empty socket on the left side, no change. Anyone have any suggestions??
92 Bonneville SSE | L67/4T60E | 70K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 175k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 180K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 234k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
James May wrote:
Hello.
PostPosted: Thu Jan 30, 2014 10:37 am
The bulb does not have 0 resistance. Don't know what it is, though. Measure one and get a similar resistor.
PostPosted: Thu Jan 30, 2014 11:18 am
Then the meter at work must be broken. Color me surprised. :lol:
James May wrote:
Hello.
PostPosted: Thu Jan 30, 2014 11:48 am
I've just thought of something, I need the resistance measured of the ballast on the right side where it's taking signal from, and match that to put in as a fooler on the left. Because if I remember right the lamp monitor looks for the resistance of one side vs another to be the same before it trips. Because when we just had one side of the HID harness plugged in and the 9006 on the other, the monitor still came on. So that will be easy as pie then.
James May wrote:
Hello.
PostPosted: Fri Jan 31, 2014 10:49 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Photo-resistor circuit, which triggers a relay to 'open' circuit a resistor, completely separate the HID circuit from the lamp module. Just have to find a way to measure the resistance of the bulb while it's illuminated, so you keep the function?
I don't know how much boost it takes to blow the tires off. But I know how much I'm going to use!
Runs:
'93 Pontiac Bonneville SSEi - Twincharged, manual, racecar! Build thread
'97 Chevy Camaro - 3800, T5, T-tops, Getting ready for some major upgrades!
'97 Buick LeSabre - L67 project, future winter DD
Doesn't run:
PostPosted: Fri Jan 31, 2014 2:13 pm
You'll have to explain that in more detail Matt. I also remembered that I haven't yet installed the bi-xenon/high beam cancellation wiring harness thingy, so that will take up the plug on the left and possibly add resistance. But I don't think it will be enough to make the monitor play nice.
James May wrote:
Hello.
There are no new unread posts for this topic. Lamp Monitor - Tail Lamp is on. Tail lights not working
abedj
Sat Nov 14, 2009 10:46 am
There are no new unread posts for this topic. Attachment(s) Driver information center - Washer fluid and Lamp Monitor
jonnevilleSSEi
22
2459
Fri Jun 24, 2011 8:55 pm
jonnevilleSSEi View the latest post
There are no new unread posts for this topic. Low coolant, Lamp Monitor, Brake/tail light warnings
Troxartes
Sat Jun 08, 2013 6:49 pm
Pontiac1 View the latest post
There are no new unread posts for this topic. Rear Reading Lamp / Interior Lamp Out.
jonnevilleSSEi
Sun Jan 02, 2011 8:33 pm
There are no new unread posts for this topic. Rear ELC Trick
99ssei
53
4621
Thu May 21, 2009 6:14 pm
99ssei View the latest post
