It is currently Tue Jul 14, 2020 3:01 pm
PostPosted: Thu Sep 19, 2013 11:27 am
I need to flush the old junk out and change the filter. The fluid im using is fod dextron 6 and is a full synthetic. Ok to use in my 93?
09 Pontiac Vibe AWD
01 Pontiac Sunfire GTX
84 Chevrolet Citation
PostPosted: Thu Sep 19, 2013 1:01 pm
Year and Trim: 1996 Regal Custom
Some transmissions will work fine on just about any fluid but a few will only work on the factory fill.
People that have never had any trouble switching fluids love argue about this.
My 96 Regal will only work properly with DexIII clone fluid. I tried switching to synthetic Vavoline Maxlife and the transmission started whining and having sloppy shifts after one week. I had to do a couple drain and fills with Castrol Dex/Merc to get things back to normal. I had to pick an aftermarket fluid because AC Delco no longer sells Dex III.
After going through this I will only use factory fill transmission fluid from now own.
PostPosted: Thu Sep 19, 2013 4:45 pm
Apparently Dex VI is backwards compatible.
PostPosted: Thu Sep 19, 2013 5:00 pm
Is it backwards compatible. It should work in a 4T60. Our lookup at work dictates Dex 6 for about every GM trans it lists. With the exception of old old transmissions like TH350/400 etc. I haven't looked up a 4T60 but I'd imagine it would be fine.
91 Buick Riviera | S2 L67 swap/4T60E | 124k mi | Antelope Beige Metallic w/Tan Int | Beat-up Beater / Cool Digital Dash
92 Pontiac Bonneville SSE | L67/4T60E | 75K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Rusty Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 197K | White Diamond Metallic w/Shale Int. | Rust Free Southern Sourced Storage Occupant
99 Chevy Tahoe LT | L31/4L65E | 246k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig / Portable Concert Hall
04 Cadillac Seville STS | L37/4T80E | 216k mi | Red Jewel Tintcoat w/Shale Int. | Storage Occupant Too
05 Cadillac Deville | LD8/4T80E | 146k mi | Black w/Two Tone Tan Int. | Livery Pkg Daily
James May wrote:
Hello.
PostPosted: Thu Sep 19, 2013 7:48 pm
The only concern is the additional detergents in synthetic. If your tranny is being held together by crud, then when the crud gets broke loose, your tranny will soon follow.
PostPosted: Thu Sep 19, 2013 10:04 pm
Im pretty sure the transmission is good. Its already the second one for this car. No slippage and shifts the very best. The fluid is red, but looks a bit old and darkish. Last one went bad at 400, 000 kms and that was because trans fluid and antifreeze don't mix. :eek2:
I am getting ready to install a tcc solonoid and basically the tranny has to be dropped for this job. That is why I asked.
09 Pontiac Vibe AWD
There are no new unread posts for this topic. 4T60 E Fluid capacity??
2000Silverbullet
14
5396
Thu Feb 25, 2010 12:08 am
There are no new unread posts for this topic. Time for a different tranny. need 4T60-E Gear ratio info
kcirrab
Wed Apr 17, 2013 11:32 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Tranny Fluid
Ragsdale
Mon Dec 08, 2008 8:25 pm
There are no new unread posts for this topic. Tranny Fluid Myth
jdronzek
22
4985
Wed Aug 19, 2009 7:27 pm
Ol' Timer View the latest post
There are no new unread posts for this topic. Suck tranny fluid out the dipstick tube?
zirconx
Wed May 28, 2008 3:30 pm
Blownville View the latest post
