It is currently Mon Apr 12, 2021 3:17 am
PostPosted: Sun Jul 21, 2013 3:10 pm
Year and Trim: 1997 Grand Prix GTP
How can I tell which mounts are bad? When I take off in 1st gear, I can hear a clunk and then it goes.. same thing if I downshift to slow down.. clunks then slows down. Sounds like a mount/mounts are bad
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
PostPosted: Sun Jul 21, 2013 4:25 pm
For the front trans mount: get someone to help you and have them watch to see if the mount pulls apart while you put load on the engine in drive with your foot on the brake.
For the driver's side rear trans mount: repeat that process the best you can with the car in reverse. Look for excessive engine/trans movement at the corner.
For the passenger engine mount and the passenger dogbone mount, they typically fall apart when failing.
PostPosted: Sun Jul 21, 2013 4:30 pm
ok thanks
PostPosted: Sun Jul 21, 2013 4:35 pm
Looking at your sig and info, I only see a GTP. This is for a 92-99 Bonneville, right?
PostPosted: Sun Jul 21, 2013 4:44 pm
difficult to replace?
97 gtp.
PostPosted: Sun Jul 21, 2013 4:51 pm
Those mounts are completely different. Disregard my instructions.
I'll let other people chime in who own or have owned a 97-03 W-body.
PostPosted: Sun Jul 28, 2013 10:26 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
W-body mounts: Engine are a mount under the HB (torque axis type) and two braces on top. Trans also has a mount directly opposite the engine mount (again torque axis type). I recall that my brother had to change both of the lower mounts on his car, they were a nasty hydraulic oil mess, but the upper mounts were fine. You should still be able to see the lower mounts separating if you follow the instructions on torque-braking the engine above (I'd think). The uppers shouldn't really move much, definitely should not have any slop.
L67 Cavalier
There are no new unread posts for this topic. Motor or Tranny mounts?
irish91983
Fri Oct 29, 2010 2:02 pm
There are no new unread posts for this topic. Motor mounts
LeSabreUltra
Sun Nov 29, 2009 5:46 pm
LeSabreUltra View the latest post
phatdaddymackc
Tue Apr 02, 2013 3:16 pm
There are no new unread posts for this topic. Solid Motor Mounts?
99ssei
Fri Jul 18, 2008 5:56 pm
superchargedSSEi View the latest post
There are no new unread posts for this topic. Why you shouldn't put off replacing motor mounts
skregal
Sun Mar 13, 2011 5:04 pm
Bing View the latest post
