It is currently Thu Feb 21, 2019 4:05 am
PostPosted: Thu May 16, 2013 6:11 am
Year and Trim: 1995 Pontiac bonniville se
I have a 1995 pontiac bonn. the other day it barely started. When it did it shook. I smelled gas also. when i barley press the accelarator down it really shakes rough. when I het the gas it is very sluggish. No back firing no engine light nothing.. when I am at cruising speed seems to be ok but once again no power.. also at drive in when idleing really bad gas smell....could i be a bad coil, egr valve, oxygen sensor? I dont know
Thank YOu
Watchmasters
PostPosted: Thu May 16, 2013 9:28 am
Year and Trim: 1998 Pontiac Bonneville SSEI
I would be interested to know this as well. I have a 98 bonnie ssei and mines doing this to. Also when I rev it hits 4k it like acts as if its limited and jumps down. I dont know what to think.
PostPosted: Thu May 16, 2013 9:52 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Yes, ignition (plugs / coils / wires) are the first thing to check.
Runs:
Doesn't run:
PostPosted: Thu May 16, 2013 11:32 am
Unplug the MAF sensor and see if the condition changes.
PostPosted: Thu May 23, 2013 7:09 am
Year and Trim: 1993 SSE
Member since Nov 2003
Check for a break in the fuel line too. Had a critter chew through mine.
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
PostPosted: Thu May 23, 2013 5:23 pm
Year and Trim: 99 Bonneville
Pull the vacuum hose off the fuel regulator and check if you smell gas.
The diaphragm probably went out. And the rail pressure is wrong.
Gas smell is the tip off.
90 SSE Bonneville Sold but not forgotten.
PostPosted: Thu May 23, 2013 8:39 pm
Year and Trim: 2003 SE
+1
There are no new unread posts for this topic. Loss of power and now I can't start my 1995 SSE
kwc27
Fri Jun 24, 2011 11:49 pm
allwhite View the latest post
There are no new unread posts for this topic. 94 Bonneville SLE Sudden Severe Power Loss
'TilWheelsFallOff
Wed Oct 28, 2015 5:50 pm
RJolly87 View the latest post
There are no new unread posts for this topic. 1995 Pontiac Bonneville SE
614justin
Tue Feb 06, 2018 6:10 am
Bugsi View the latest post
There are no new unread posts for this topic. 1995 pontiac bonneville se ICM change
614justin
Sat Aug 06, 2016 10:48 pm
614justin View the latest post
There are no new unread posts for this topic. 1995 Pontiac BonneVille Mechanical Issues
jahmal804
Fri Jan 04, 2013 1:52 pm
jahmal804 View the latest post
