It is currently Tue Apr 16, 2024 2:00 pm
PostPosted: Fri Nov 23, 2012 8:51 pm
Year and Trim: 98 Lesabre custom
I am considering doing a rebuild on my transmission and I was wondering if anyone could tell me how to remove the valve body bore plugs in order to check out whats inside?
Thanks in advance
PostPosted: Fri Nov 23, 2012 9:12 pm
Year and Trim: '99 Montana
'92 Trofeo
there are clips that hold caps in I believe. It's been a while, the last one I had open was a 700r4, and it uses clips, roll pins, and snap rings. But I think it's just clips in the 4t65.
PostPosted: Fri Nov 23, 2012 9:15 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Probably Jesus clips
PostPosted: Fri Nov 23, 2012 9:37 pm
Thanks for your reply. Double checking the documentation I have It appears you are correct. I was thrown off by the line boost valve bore plug which appears to have the retainer going through the reverse boost valve bushing, and the 2-3 Accumulator valve bushing retainer.
There are no new unread posts for this topic. Spark plug wire channel on front valve cover? SOLVED!
Bob Dillon
Sun Mar 17, 2013 12:59 pm
There are no new unread posts for this topic. 4T60-E valve body space plate for solenoid replacement?
Saturn Simon
Mon May 28, 2018 11:06 am
Saturn Simon View the latest post
There are no new unread posts for this topic. Head exhaust valve replacement -valve job
impala67
Thu Dec 11, 2014 5:03 am
impala67 View the latest post
There are no new unread posts for this topic. How do I remove FPR?
imidazol97
Thu Nov 12, 2009 10:38 am
azu View the latest post
This topic is locked, you cannot edit posts or make further replies. how to remove can sensor
xvr843
20
4477
Tue May 03, 2011 11:29 pm
willwren View the latest post
