It is currently Fri Mar 22, 2019 6:27 am
 Post subject: Bonneville wont start?
PostPosted: Thu Jul 24, 2008 2:06 pm
Year and Trim: 1997 Pontiac Bonneville special edition
Hello everyone just tried getting into my car and my Bonneville would not start, Im guessing its the battery but I ended up turning all the things off before I got out of the car so not sure what could have drained the battery if its the battery. But anyways anyone else have any idea what it could be? When I try turning it out nothing happens no sound or anything the car just sits there?
PostPosted: Thu Jul 24, 2008 2:28 pm
Year and Trim: 1994 SSEi 1999 SLE
Seems to be the battery. It could have died arbitrarily with no warning signs, as two of my batteries have done so far. Do you have a replacement? Don't try jump-starting the car without replacing the battery first, or you may end up riding on just your alternator the entire time.
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
PostPosted: Thu Jul 24, 2008 3:17 pm
could have been power antenna, ELC shocks, or any number of things. Like randomir said, batteries also just die sometimes. swap one in from another vehicle to make sure that is the problem if you can, and go from there.
PostPosted: Fri Jul 25, 2008 12:00 am
Year and Trim: 1992 SE
Were there any other symptoms the last few times you drove it? Headlights dim, or dim instrument panel would point to battery, or perhaps the alternator. Or both? However, if you noticed a sudden loss of power, or sluggish acceleration, it's possible that your fuel filter could be clogged, or you could have a bad fuel pump. The battery is the easiest thing to check, and most likely if you don't hear anything when you turn the ignition, so
PostPosted: Fri Jul 25, 2008 12:02 am
Not that I'm too informed or anything, but I have been told he's gotten the car running. Something about the positive cable having corrosion. The battery was replaced, but the inside of the positive wire was corroded, and some the screw wouldn't come out. That's some corrosion! :bluetwitch:
There are no new unread posts for this topic. 98 bonneville wont start sometimes
vincet79
Mon Sep 06, 2010 10:09 am
willwren View the latest post
There are no new unread posts for this topic. '92 bonneville error 58 and wont start.
pontiacian
Sat Sep 03, 2011 10:56 pm
There are no new unread posts for this topic. 99 Bonneville SE Stalls and Occasionally Wont Start!
bean1491
Fri Aug 06, 2010 4:23 pm
bean1491 View the latest post
There are no new unread posts for this topic. 1995 bonneville wont start and fuel pump relay clicking
zach
Mon Jun 15, 2009 9:50 am
There are no new unread posts for this topic. Car wont start! need help
calaeb0896
Tue Jul 15, 2008 2:17 pm
zuper8 View the latest post
