It is currently Tue Apr 16, 2024 1:02 am
PostPosted: Thu Jul 24, 2008 1:00 am
Year and Trim: 1995 SSei
1987 GN 16K Original
Alirght my car is leaking oil off the oil filter area, The filter is tight, but the oil seems to be seeping or something from the lines going to the oil filter, anyone have any suggestions of were it could be leaking from other than the lines? If this makes any sense( series 1 supercharged)
thanks
PostPosted: Thu Jul 24, 2008 1:47 am
Year and Trim: 2007 Grand Prix GT
Is the oil sending unit near the filter on a S1 L67? My guess would be sending unit, oil cooler lines if you have them, or the bolts that go to the filter adapter are loose.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
PostPosted: Thu Jul 24, 2008 7:55 am
Year and Trim: 01 Buick Century Limited
10 Toyota Avalon XLS
Is it worth checking to see if maybe the gasket inside the oil filter may have slipped out of place or maybe the old rubber gasket is still there. Reason I ask is because I did an oil change once and I was in such a hurry that I didn't check if the old gasket came off. It took approximately 2000 miles before it started developing a leak.
As for the lines, I changed mine on the 90 SSE and had to get both the supply and return from the dealership. Other shops told me they could make them up but I had to give them the size, fitting type, length etc. Either that or just match up the old lines. I assume yours are going to the radiator?
PostPosted: Sun Jul 27, 2008 9:35 am
Year and Trim: 1993 SSEi with full trim package
I had the same problem. Mine was leaking from the oil cooler lines. Picked up some O.E.M. lines from the dealer and TADAHHH....no more leaks from there.
ImageAMSOIL EAO23 Oil Filter, Fram Platinum Air Filter, Royal Purple Synthetic 10W30
PostPosted: Sun Jul 27, 2008 1:32 pm
LIM valley seal blew out? that was it
PostPosted: Sun Jul 27, 2008 2:43 pm
you say that with a ?, are you unsure?
yourgrandma wrote:
High
PostPosted: Sun Jul 27, 2008 7:15 pm
Year and Trim: 1997 SSE
my oil filter always used to drip oil right up until I replaced the oil pan gasket, now that whole area is nice and dry.
-Chris
1992 Chevrolet Lumina Z34 3.4L TDC v6, Hydramatic 4T60E
1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
PostPosted: Mon Jul 28, 2008 5:04 pm
its fixed I could see the valley gasket sticking out,
There are no new unread posts for this topic. Fuel line leaking after fuel filter change
dangrus4060
Wed Mar 02, 2011 10:03 pm
sandrock View the latest post
There are no new unread posts for this topic. Leaking oil pan gasket?
LeSabre in Buffalo
15
4736
Tue Sep 07, 2010 1:33 pm
There are no new unread posts for this topic. Heat leaking
MossyOak10
Thu Oct 02, 2014 9:49 am
Sirius View the latest post
There are no new unread posts for this topic. tranny still leaking
glenn304bonne97
Mon Jan 30, 2012 2:25 am
renchjeep View the latest post
There are no new unread posts for this topic. Coolant Leaking...
nunesjeff
Tue Nov 03, 2009 1:39 am
