It is currently Sat Feb 16, 2019 3:27 pm
PostPosted: Fri Sep 07, 2012 12:36 am
Year and Trim: 1995 Pontiac Bonneville
My Bonneville is a 1995...........not supercharged.
I am trying to locate a used engine but unsure how to find out what other Bonneville years will interchange with my 1995.
Help please!
PostPosted: Fri Sep 07, 2012 10:00 am
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
If you are looking for a straight swap don't change anything.
Look at car-part.com. It shows compatible models and years.
Many others would work also by swapping some of engine accessories, brackets, etc.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Fri Sep 07, 2012 10:38 am
For a zero work, straight drop in, only a 95 SE will drop right in.
Any series 2 L36 or series 3 L26 engine will work in your car but the work required varies
For a 95-99 H-body engine you swap over the original throttle body, knock sensors, rear exhaust manifold, and original wiring harness.
For a 2000-2003 H-body you swap over the same plus passenger motor mount, tensioner assembly, and oil filter bracket along with that.
For a 97-99 W-body, it would be the same as swapping in a 2000-2003 H-body but instead of swapping the tensioner, you would swap the coil pack bracket.
For a 2000-2003 W-body the same as a 97-99 W but add the tensioner assembly.
For any L26 2004+ 3800 Series III, It could be the same as either a 2000-2003 H or W but you'll also have to swap your stock upper intake manifold or updated dorman upper (recommended for less chance of failure).
The best option is the last but it requires the most work.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Fri Sep 07, 2012 10:58 am
68 w/400
94 SSEi
IMO, the L26 would be the best bet if you plan to keep the car.
You will have a pretty much bullet proof engine.
And they can be found cheaper with less miles because they are not in as high demand as the older engines are.
Clay
There are no new unread posts for this topic. 1995 SSEi Driver Information Center
Ingo0123
Mon May 23, 2011 7:17 pm
Ingo0123 View the latest post
There are no new unread posts for this topic. 1995 Bonneville with series one engine?
Johnny2521
Wed Jul 17, 2013 10:07 am
Johnny2521 View the latest post
There are no new unread posts for this topic. 1995 Engine Cradle Dropped
voxetros
Wed Nov 06, 2013 12:36 pm
There are no new unread posts for this topic. 1995 Oldsmobile LSS Supercharged - Engine Knock
89OldsRocket
Fri Jan 13, 2017 2:39 am
J Wikoff View the latest post
There are no new unread posts for this topic. Engine Swap Help: 1995 Series II into a 1998
DieselMechanic
36
8524
Thu Feb 16, 2012 10:54 pm
DieselMechanic View the latest post
