It is currently Sun Jan 20, 2019 12:23 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Post subject: knock sound
PostPosted: Mon Dec 12, 2011 5:02 am
I have a knocking sound that comes and goes and is fairly quiet and usually presents itself when fully warm after a drive. It's about once every second. It is coming from the engine at the passenger end and sounds internal maybe, at least in top end. Valves? Bearings? Could my 1.8 roller rockers need adjustment? I remember the rocker noise being a lot lighter of a sound and faster. If it's not that what else could it be? :eek2: :sadeyz: :bluetwitch:
great car. Wrecked
Burnt Bonny.
 Post subject: Re: knock sound
PostPosted: Mon Dec 12, 2011 5:36 am
Year and Trim: 99 SE
99 Suburban 2500 LT
68 Beetle
Not sure if it could be the harmonic balancer, but it is an easy check. Just pull your belt loose (engine not running) and see if you can move or twist that thing at all. There should be no movement in it. Then start the car up and run it for just a short time (remember your water pump isn't working right now). See if there are any different noises or lack there of. This will at least let you eliminate some possibilities.
1999 Bonneville SE with the heart of a 07 Grand Prix
PostPosted: Mon Dec 12, 2011 7:09 am
viewtopic.php?f=19&t=25803
You didn't answer all these questions, particularly whether it's vehicle speed related or engine RPM related. Your oil pressure would be a help also. You're not really giving us anything to go on at all.
If it's only at idle, and goes away as you nudge the throttle, it's the harmonic balancer. If not, it's probably the motor if it's rpm related. The rockers don't need (nor is there any) adjustment. I assumed you would know this since you are the one that installed them.
PostPosted: Mon Dec 12, 2011 4:23 pm
willwren wrote:
http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=19&t=25803
I haven't checked on whether it varies with engine speed or not. I will do that next time I hear it. I've only heard it while parked. I do NOT have the Supercharger and so I don't think I have a harmonic balancer. My oil pressure is fine. It varies between 40 and about 90.
I will listen more carefully for the RPM related concern the next time I hear it.
:dontknow:
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Dec 12, 2011 5:26 pm
Every engine has a harmonic balancer, on these cars it also serves as the crank pulley. I do not know of a single engine that can survive without some sort of balancer...
PostPosted: Mon Dec 12, 2011 5:46 pm
Chris, I'm very well aware of the fact that you have an L27 with no supercharger.
Your harmonic balancer is right below your water pump. The rubber erodes, allowing the inner and outer halves to clank. It's more of a clatter than a knock though, and if it doesn't go away as you tip into the throttle in idle, it's the motor, not the balancer.
PostPosted: Tue Dec 13, 2011 3:28 am
Well I feel ignorant. I helped rebuild a couple motors as a kid but I don't remember hearing anything about it. Is there a thread that discusses the complete operation of these motors? I will have to search and read the FSM too.
Wasn't doing it today. The sound I remember sounded more of a knock. I will look at the HB tomorrow in the light.
great car. Wrecked
Burnt Bonny.
PostPosted: Tue Dec 13, 2011 8:48 am
Pull on the belt. The harmonic balancer shouldn't move more than 1 or 2 degrees. If it doesn't move and doesn't make any noise, it's the motor or something else mechanical. Most likely the motor itself due to the noise being at idle and not moving. That rules out steering and suspension, as well as transmission.
PostPosted: Mon Jan 16, 2012 1:00 pm
I had the noise again after my road trip. It was 140 mi on Wa State fwy. So it was like 75-95 throughout the drive. When I pulled into the store the sound was present. I didn't check for exactly where the noise was coming from, but just tapped the accelerator and it disappeared. I'm gonna finally pull the belt and check the HB as soon as the snow stops or as soon as I can get out there anyway.
I was pricing a new HB at about $70 rockauto.com. They also have available an HB repair sleeve. Will either or both of these fix my HB if that's the problem? And how involved are both of these repair procedures?
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Jan 16, 2012 1:05 pm
The repair sleeve is to fix a worn shaft where the front seal rides to stop an oil leak. Nothing to do with the worn rubber.
PostPosted: Mon Jan 16, 2012 2:20 pm
I thought this would be simple check. With the belt on I get movement of the HB pulley. About a inch+ belt travel until the crank is too hard to turn. With the belt off the HB still turns until the crank is too hard to turn. As far as top to bottom and side to side movement there is no discernable movement.
The sound is only after coming to a stop to idle shortly after sustained RPMs/Speeds and a touch of throttle clears it. It sounds from or behind water pump / HB area
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Jan 16, 2012 2:29 pm
With the belt off, the HB should not turn BY HAND. Don't expect rocket science. It should be rigid. Visually inspect the face of it for cracks in the rubber around the outer perimeter just under the edge of the belt grooves. This is a 5-minute diagnosis that should have been done a month ago.
PostPosted: Mon Jan 16, 2012 2:40 pm
Year and Trim: 1992 SSE (sold), 1992 SE (sold), 1995 ?? (buying?)
You don't want to turn the HB far enough to turn the crank, just try to rock it back and forth and see if there's anymovement to the HB before engaging the crank.
While you had the belt off did you check for play in any of the accessories?
Also, when you say a touch of the throttle clears it, do you mean that if you touch the throttle and let off the noise is gone, or does it come back when you let off?
PostPosted: Mon Jan 16, 2012 3:25 pm
willwren wrote:
... This is a 5-minute diagnosis that should have been done a month ago.
Thanks for making this clearer. Before I was thinking the rubber was in between the front and rear HB faces and I couldn't find it. The Rubber is in tact on the front face with no deterioration or cracks. No doubt about it though: with belt off I can turn the HB 1/4 turn or so by hand. Again I get no wobbly motion, just rotation around the crank shaft axis
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Jan 16, 2012 4:48 pm
that's what I wanted to know movement w/o engaging the crank- I don't thinks so. I think the movement I feel is with the crank engaged- I'll check again
I will check the other accessories at that time.
The throttle kills it, it does not come back. This indicates HB and not internals?
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Jan 16, 2012 4:51 pm
[/quote]
Also after rereading Will's post I think I need to further check under the lip of the HB rim to see if the rubber there has deteriorated.
great car. Wrecked
Burnt Bonny.
PostPosted: Tue Jan 17, 2012 5:25 am
There was no HB freeplay at least with the belt on.
None of the accessory pulleys seemed to be loose.
I could not get a good enough look at the rubber under the rim of the HB Pulley to see if it has deteriorated
great car. Wrecked
Burnt Bonny.
PostPosted: Tue Jan 17, 2012 11:23 am
Noisey at idle and goes away when accelerating - y/n
noise goes away at idle with belt removed - y/n
you can turn the outer pulley by hand and the crank does not turn (with the belt off) - y/n
If you answer yes to all 3 of those, I will put my money on the HB being bad. Is it bad to runit like that, no, but it will only get worse. You can also get them from the Pick and Pull pretty cheap if you are low on cash, but do not expect it to last 100k.
PostPosted: Tue Jan 17, 2012 11:34 am
You're not getting it. If the HB is moving that far, it's bad. Forget your other accessories if the HB is doing that with the belt off. Think about it for a minute.
And your rubber is NOT intact if the HB is moving that far. You're missing the rubber separation around the outer edge. It's a crack you're seeing, not a dark line.
PostPosted: Tue Jan 17, 2012 4:06 pm
Y, unknown, N
It seems very clear to me about the movement of the HB. There is NO freeplay. It moves with much force and it is obvious it is turning the crank right off.
The only time I get the knocking noise is at idle after hard long distance driving. As such it makes it difficult to check things. Like I can't kill the motor, remove the belt and retest. Just touching the accelerator kills it and it doesn't come back.
I think it's a bearing or something, but I will (today or tomorrow) recheck for free play again. With my motor sick I cringe at running hard down the freeway 50 miles
great car. Wrecked
Burnt Bonny.
There are no new unread posts for this topic. What goes knock knock knock then stops?
crash93ssei
Sun Jan 25, 2009 10:00 pm
crzydmnd72 View the latest post
There are no new unread posts for this topic. knock ? kr
Adam Marcum
Sat Jul 26, 2008 2:30 am
bill buttermore View the latest post
There are no new unread posts for this topic. knock on 93
bonnie_99
11
2043
Fri May 27, 2011 9:38 pm
bonnie_99 View the latest post
There are no new unread posts for this topic. Rod Knock
NOT_aerosmith
Wed Jul 06, 2011 11:13 pm
NOT_aerosmith View the latest post
There are no new unread posts for this topic. Knock Sensor?
irish91983
Sun Sep 27, 2009 1:41 pm
rharper View the latest post
