It is currently Sat Feb 16, 2019 5:33 am
PostPosted: Thu Jul 21, 2011 11:08 pm
Year and Trim: 1997 SSEi 40th Anniv
hi,
swmbo drove the car into the garage one night and the next morning, it wont start, i tried my key, nothing.
in retrospect, the fuel pump wasnt running, (it's one year old).
checked the maxifuse, fuses and relay, all good.
battery was a tad weak and it was replaced.
a couple people said to take the after market "ultra-start remote starter" which i did.
it was not soldered or crimped, just wire twisted around wire.
a big orange wire had several strands broken.
the white vats wires (covered with an orange sheath) had a ~4.68 resistor soldered in place to defeat the vats.
my key was read in a vats machine and was determined to be #11, (4.75 ohms). both keys read ~4.68 ohms with my multimeter
i just wrapped these wires together to see if it would start, but it didnt.
sometime during this process, the fuel pump ran for a few seconds and rather than check the pressure at the rail, i tried to start it, no luck.
the security lite is steady upon entry to the car, (with the door open), and flashes 1/sec after cranking and goes out whan the door is shut.
so the fuel pump is not working. i feel it is due to the security, vats, remote starter, pcm but can not find the cause.
is there a way to force the pump to run by over riding these systems?
any other suggestions before i have it towed to the local chevy dealer?
tia
very frustrated,
peter
PostPosted: Thu Jul 21, 2011 11:47 pm
I have a bit of info that you may find helpful. On my 1994 SE there is a device that further deters theft. If the car OEM Anti-Theft systems is triggered it will cut off the injectors. There is a chip you can find on Ebay etc that overrevs this system and feeds the CPU/ECM the right code to enable the injectors IIRC. Definetly check your FP. My 94 registers fuel pressure when the key is just turned to run (not start). There is also a Fuel pump relay that is reported to go out and a fuel pump fuse under the passenger dash, on my 94 SE...
great car. Wrecked
Burnt Bonny.
PostPosted: Fri Jul 22, 2011 7:37 am
---i think on mine, it cuts the signal to the pcm/fp.
----the fp has engaged twice during this process...
----yes, to prime the system.
----i swapped that with the fog light reply, both are good
----and a maxi fuse in the engine compartment
----the saga continues, i guess i will wait until monday to tow it to the dealer :(
thanks,
peter
PostPosted: Fri Jul 22, 2011 8:34 am
Year and Trim: 2012 Eco
Security light shouldn't be on when the door's opened. Something's messed somewhere in the wiring associated with that, or with the remote starter that was removed.
PostPosted: Fri Jul 22, 2011 2:06 pm
Year and Trim: 99 SSEi
Just to be 100% clear, is the starting turning over the engine?
The fuel pump just runs for 2 seconds when the key is turned to run. Turn the key to run a few times then check for fuel at the rail by pressing in the schrader valve.
Got gas?
2006 Chevy Monte Carlo SS
There are no new unread posts for this topic. Cannot diagnose crank no start condition on 95 ssei
Vernon001
Sat Feb 24, 2018 12:50 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Sudden Acceleration. Bad TPS ?
Madcarpenter
Sun May 06, 2012 11:54 pm
There are no new unread posts for this topic. 94 SLE Sudden Gas Mileage Drop
festpace
16
1576
Wed Mar 23, 2011 9:52 pm
Bonnefied_GM View the latest post
There are no new unread posts for this topic. Sudden Wheel Bearing(?) Noise
repinS
Mon Feb 09, 2009 8:12 pm
repinS View the latest post
There are no new unread posts for this topic. 97 SSEi Won't Run After Start
EluZioN
11
1439
Mon Apr 07, 2014 10:24 pm
EluZioN View the latest post
