It is currently Thu Dec 13, 2018 10:00 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 14, 2011 12:41 pm
Year and Trim: '97 SSEi
That didn't work as expected, I unplugged the sensor, indicator still lit. Even connected a wire to create what I think would be a solid circuit from the line in to out and the indicator was still on. hmmmm. Other display functions except Lamp Module are fine.
PostPosted: Tue Jun 14, 2011 1:55 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
That means you have a short to ground somewhere in your instrument panel. That could also be why your lamp monitor is on (if in fact all your lamps are good). Replacing the IP would be an easy test. You shorting the wire would cause the light to come on, that is why the test is to remove the sensor. That creates an open that should turn off the light. Dig up an IP and swap it in to test.
PostPosted: Fri Jun 24, 2011 8:55 pm
Dig up an IP? IP as in "Instrument Panel"? Dig up like "casually see if I have one in the shed"? hmm, problem with that for me is that by the time I locate and buy one I suspect I'd be as likely to trade off one malfunction for others unless I bought one new, in which case, it may not be a reasonable purchase (for this kid during these hard times). IP may also be "Internet Protocol" but I doubt it. Am I correct? you're suggesting I swap out the panel to see if that's it? Even if another panel had other issues, I might still learn from the experience. When time and money suggest alignment I'll keep it in mind. The logic sounds accurate, thanks for helping me see how this works. ;) I'll keep my eyes open for a panel, would be nice to have light sensors and a washer sensor I can trust.
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
There are no new unread posts for this topic. Driver Information Center died :(
nickdalzell1
Sat Sep 08, 2012 7:39 pm
nickdalzell1 View the latest post
There are no new unread posts for this topic. 1995 SSEi Driver Information Center
Ingo0123
Mon May 23, 2011 7:17 pm
Ingo0123 View the latest post
There are no new unread posts for this topic. Driver information center doesn't work properly
cinzy0
Wed Aug 23, 2017 2:38 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Lamp Monitor - Tail Lamp is on. Tail lights not working
abedj
Sat Nov 14, 2009 10:46 am
There are no new unread posts for this topic. How to trick the lamp monitor?
SSEiMan01
Fri Jan 31, 2014 2:13 pm
