It is currently Tue Apr 16, 2024 6:43 pm
 Post subject: 97 Won't crank over
PostPosted: Fri Mar 11, 2011 7:27 pm
Year and Trim: 1997 Bonneville SE
The car has been sitting for couple years, someone ran into the back. I'm fixing the damage & I replaced the radio.
I installed the radio & I notice the left rear speaker wasn't working so I checked the power & ground and in the process I blew a fuse. I replaced the 10A fuse. Now the car won't crank over for some reason. I checked the driver side fuses via test light & visual, same on the passenger side & test light under the hood. One of fuse relays on the passenger side clicks every time I try to start it, I changed it out with a another relay and nothing changed. I did jump start the starter & fired right up but it dies in like 5 seconds.
The security light blinks.
I'm lost on what to check.
1997 Pontiac SE Bonneville
 Post subject: Re: 97 Won't crank over
PostPosted: Fri Mar 11, 2011 7:35 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Have you disconnected the battery(for 12 seconds) and reconnected and try to start after that?
PostPosted: Fri Mar 11, 2011 7:43 pm
I did that, left it for about 10 minutes.
PostPosted: Sat Mar 12, 2011 12:07 am
Year and Trim: 99 SSEi
Double check all the fuses. Triple check 1a & 2e, both are 10 amp & used by the security system.
2006 Chevy Monte Carlo SS
PostPosted: Sat Mar 12, 2011 1:38 am
Year and Trim: '97 SSEi
I doubt this relates but when I was working on my radio I left the interior lamps (and she has LOADS of them) on for the period and the car wouldn't start after the work was done. After a jump start everything was fine. A mechanic/friend told me I had enough power for everything else but not enough to crank the starter. I'd heard a rapid clicking which I learned is the "solenoid" that activates the starter, If there isn't enough juice behind it. All you get is clicks and no VROOOM. Confused about why it would run for 5 secs and stop but sometimes unrelated things happen at the same time. After sitting as long as she has you may be experiencing two semi-unrelated issues. The security light may also mean something, you have the manual? If not let me know and I'll see if mine suggests anything. ~Good luck.
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
PostPosted: Sat Mar 12, 2011 2:16 am
I'll double check the fuses tomorrow & see what happens.
It might be the vats problem. :banghead:
PostPosted: Sat Mar 12, 2011 9:55 pm
It was the vats. :bwoohoo:
PostPosted: Sat Mar 12, 2011 10:22 pm
Was it just a fuse or did you have to bypass the ignition switch contacts?
PostPosted: Sun Mar 13, 2011 12:11 am
VATS? = (Vehicle Anti-Theft Security?)
PostPosted: Sun Mar 13, 2011 10:23 pm
Yes I had to bypass the vats.
There's allot of threads about bypassing the vats.
There are no new unread posts for this topic. 94 SE won't crank.
roadkills
Thu Jul 03, 2008 7:05 pm
Aaron88 View the latest post
There are no new unread posts for this topic. Car won't crank
JMH1950
Wed Oct 29, 2008 9:48 pm
There are no new unread posts for this topic. Crank, but won't start
cotubbs
Mon Apr 09, 2012 4:45 am
renchjeep View the latest post
There are no new unread posts for this topic. 92 SE has power but won't crank
zuper8
Sun Mar 31, 2013 11:52 pm
There are no new unread posts for this topic. crank sensor?
trf_ssei
Wed Jun 11, 2008 8:35 am
BillBoost37 View the latest post
