It is currently Tue Feb 19, 2019 7:28 pm
PostPosted: Wed Mar 02, 2011 9:09 pm
Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked
Posting after reading this... http://www.pontiacbonnevilleclub.com/fo ... =8&t=24130
I replaced my fuel filter this past weekend, relieved pressure thru schreider valve with a rag and it caught most of it...
My problem is with the plastic fuel line from the tank to the filter. I didn't loosen the end at the tank, but when I put the line back on the new filter and turned the key, it was spewing gas like crazy from the tank end of that line.
Have any of you had this happen? I took the line back off (both ends), cleaned the ends, put it back and still leaked...after working it several times, I finally got it to stop, mostly, it still dribbles a little. I searched all the auto parts and no one makes a replacement line...just repair kits...which means I'd have to buy 2 kits to make 1 new line...
I have not checked the dealer yet. Does anyone know if they still stock this line at the dealer?
Or do they make just an O-ring kit? I'm sure that that is the culprit...the line itself is good...no cracks or cuts of any kind. and the snap connectors are still in good shape.
I also replaced the front tranny mount...the rubber split completely in two...happened in just the past couple weeks...weird thing is, because of the high gas prices, I have not dogged it any...so not sure why it split....it was still in fine shape when I removed the engine a couple summers ago because of the spun #1 rod...and I regularly inspect these things...
Thanks for any comments...
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
PostPosted: Wed Mar 02, 2011 9:40 pm
Year and Trim: 2012 Eco
You'll need O-ring picks and some packages of Viton O-rings. I replaced just the O-rings after changing the fuel filter caused the same problem you are facing. There are 2 O-rings separated by a plastic spacer inside that connector. Seat the rear O-ring, slide the plastic spacer back against it, then seat the front O-ring. Using two O-ring picks helped a lot to hold the spacer in place while seating the front O-ring.
It's doable. Keep at it, it's very "fiddly"!
PostPosted: Wed Mar 02, 2011 10:03 pm
Better off just buying the connector/line combo and graft that in. Those o-rings are a beeeotch.
BonneMe wrote:
There are no new unread posts for this topic. Oil leaking from oil filter
tripscarcare95
Mon Jul 28, 2008 5:04 pm
tripscarcare95 View the latest post
There are no new unread posts for this topic. Quick Q's on fuel line connection to fuel rail on S/C
charliemax
Sun Oct 11, 2009 11:16 pm
charliemax View the latest post
There are no new unread posts for this topic. tranny shifts hard after fluid/filter change
Flaggship
Tue Sep 29, 2009 11:49 pm
1fatcat View the latest post
There are no new unread posts for this topic. Fuel Lines Leaking!
LeSabre in Buffalo
41
7910
Fri Sep 19, 2008 5:01 pm
agrazela View the latest post
There are no new unread posts for this topic. 96SE Fuel Pipe leaking and confusion at the dealers
Pilgar
Tue Feb 03, 2009 11:18 am
