It is currently Sat Feb 16, 2019 4:54 am
 Post subject: Hard pulling issue
PostPosted: Mon Feb 28, 2011 6:10 am
Year and Trim: 97 SE
Ive started to notice my 97 bonneville pulling left when i push on the throttle and then pulling to the right when i let off the throttle while cruising (more drasticly with higher speeds) about a week ago and its getting progressively worse. its almost too ify to drive when its snowing out because the pull has gotten so severe since i noticed it a week ago.
Anybody got any ideas as to what could be causing this?
 Post subject: Re: Hard pulling issue
PostPosted: Mon Feb 28, 2011 6:46 am
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Kind of obvious issue but have you checked tire pressure?
Otherwise it sounds like something in the front end needs replacing
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Mon Feb 28, 2011 7:10 am
Put the front on jack stands, apply the parking brake. Put the car in neutral and see if the wheels spin with little effort. There will be a little resistance from the trans internals, but it should not take a lot of effort.
When you spin the wheels, they should both rotate, but in opposite directions.
You may also want to pull both wheels off and check the brakes for even wear. If one side is worn more than the other, you may have a stuck caliper.
There are no new unread posts for this topic. Towing, or pulling?
93Bonneville
Mon Feb 06, 2012 1:58 pm
There are no new unread posts for this topic. Headliner pulling questions
J Wikoff
Thu May 07, 2009 10:34 pm
There are no new unread posts for this topic. 98' Bonneville pulling to right and shaking violently
wpbrink
Wed Jun 13, 2018 4:55 pm
There are no new unread posts for this topic. Pasive Securyt Issue or Electrical Issue, help.
97BlackSSEI
16
2112
Thu Mar 07, 2013 8:20 am
97BlackSSEI View the latest post
There are no new unread posts for this topic. Cruise control not "pulling".
57lxi
Mon Jun 30, 2008 8:14 pm
