It is currently Tue Apr 16, 2024 12:50 am
PostPosted: Mon Feb 07, 2011 11:33 am
Year and Trim: 1999 SLE 112,000mi
2002 Park Ave Ultra 88,000mi
I bought a 1999 SLE with 111,000 miles in very good condition from a local dealer last weekend, and I have a few questions.
1) The previous owner's receipts show that the lower intake gaskets were replaced with GM PN# 89017816. I can't remember whether or not the upper intake gasket was also replaced; I'll have to look through the receipts again. When I looked at the car, the coolant level was about 2" low (not a good sign) but there were no signs of any external leaks. The oil looked like normal oil - ps: how can you tell if there's dexcool in oil? The intake manifold itself has a '99 date stamp, so I assume it's original. Do I need to replace the intake manifold and upper intake gasket to ensure that the intake internal coolant leak problem won't be a problem, and if so, which intake and upper gasket have fixed the coolant leak problems? I haven't driven the car since I drove it home, and I want to look into this and ideally replace the intake and upper gasket if they need to be replaced, before I begin driving it.
2) The receipts also show that the coolant bypass elbow was replaced with GM PN# 24503423. There was no record of a 2nd coolant bypass being replaced, and I only saw 1 bypass on the engine (looks to be black plastic, and I couldn't see how it would be replaced, either). Where is the 2nd coolant bypass, and does it need to be replaced if it's still the original part?
3) I noticed that the normally aspirated Series II shifts and revs differently than my '92 SSE s/c and my '93 SSEi. The '99 SLE seems to shift a little later than both of my supercharged Series 1s, and revs at around 2,000 RPM in overdrive at around 60 MPH. Is the normally aspirated Series II supposed to rev at around 2,000 RPMs at 60 MPH? In contrast, my supercharged Series 1s both rev at around 1,800 RPMs at 60 MPH.
4) The radio appears to be the stock CD player unit with the red display. The radio and the electronic climate control seem to work ok, but when I turn on the headlights, the displays on the radio and on the electronic climate control turn off (but the radio and climate control seem to work ok while their displays are off). I'm guessing the problem is the headlight switch? If so, can I temporarily swap one from my '92 or '93 to see if that fixes the problem before I buy a replacement switch? If I remember right, the twilight sentinel/dimmer off switch is near the top (1:00 position) on the '99 SLE, but it's near the bottom (5:00 position) on my '92 and '93, so the '99 appears to be the converse of the '92 and '93, and maybe the headlight switch isn't interchangeable.
5) I also noticed that it looks like you have to remove the upper engine support in order to replace the serpentine belt on the Series II? If so, how difficult is it to replace the belt?
Thanks!
PostPosted: Mon Feb 07, 2011 2:14 pm
1.) From looking online, the gaskets you have are the aluminum gaskets. Shouldn't have to worry about them ever. However, the UIM will need replacement. Read up: http://www.pontiacbonnevilleclub.com/fo ... =53&t=1061
2.) IIRC the older cars have a steel elbow on the bottom. That upper elbow would be replaced by removing the tensioner bracket if you needed to do it.
3.) I'm guessing your car has a 3.05 FDR vs. the 2.93 on your SSE/i.
4.) No idea
5.) Yes, you have to remove the bracket. Some say it's a PITA, I've never done it myself.
PostPosted: Mon Feb 07, 2011 3:01 pm
Well, I just ordered the 'Sure Fix' upper intake kit from ineedparts.com
If that's not the best upper intake problem solution available, please let me know!
Nope, that's the best one. :wink:
PostPosted: Mon Feb 07, 2011 7:51 pm
Year and Trim: 2012 Eco
No need to remove the whole engine mount. There's a stud that needs to be yanked on the firewall side of the A/C compressor. The belt will feed through the opening that creates. It's not that hard, should be 30 minutes total to put on a new belt.
PostPosted: Tue Feb 08, 2011 9:02 am
Up through 1995 is a 2.97 ratio, not 2.93. And the Series 2 motor has lighter rotating internals, so it revs quicker and has a higher redline, all shifts are at higher rpm's.
The belt change procedure including the mount removal is in Techinfo. Link at the top of the page.
There are no new unread posts for this topic. 1996 SE New owner - Bunch of questions
Honest Bob
Sat Apr 17, 2010 12:43 am
There are no new unread posts for this topic. lots of maintenance questions for a noobie 95 ssei owner
focusmaniaczx3
47
7268
Mon Jun 04, 2012 3:17 pm
focusmaniaczx3 View the latest post
There are no new unread posts for this topic. 1999 Bonneville SE
freshinthehouse
Wed Jun 12, 2013 5:17 pm
There are no new unread posts for this topic. 1999 A/C clutch
spydog
11
2042
Mon Sep 07, 2009 12:17 am
ron350 View the latest post
There are no new unread posts for this topic. new owner of a 98 SSE, help with a/c please!
jknight8787
16
3066
Mon Aug 03, 2015 10:09 am
Sirius View the latest post
