It is currently Sun May 26, 2019 8:24 pm
 Post subject: need help fast!
PostPosted: Thu Jun 12, 2008 6:36 pm
Year and Trim: 1998 bonneville SSEi
the heat is killer and my power windows stopped working im not getting power to the brown wire on the switch and the radio stopped working at the same time. not a fuse or relay any ideas or info would be greatly appreciated!!!
 Post subject: Re: need help fast!
PostPosted: Thu Jun 12, 2008 6:38 pm
have you tried all the switches on each door?
Do the interior lights work? keyless entry?
-Andrew-
PostPosted: Thu Jun 12, 2008 8:52 pm
tryed all switches checked all fuses and the keyless entry only works to unlock it. had to connect direct power to the brown wire in the center of the the switch unit to close the windows before it rained. the switche works but its not getting power or its not grounding or somthing. there is power at all my fuses with the key on but not at the switch im at a loss. where would i find a ground for that stuff? and is the master switch a power distribution for the whole circuit?
PostPosted: Thu Jun 12, 2008 9:46 pm
Year and Trim: 99 SSEi
Here's a wiring diagram and some pictures of the driver's side ground bus & the metal bar that can corrode. Check both the driver & passenger side ground bus.
2006 Chevy Monte Carlo SS
PostPosted: Sat Jun 14, 2008 10:14 am
thanks for the help ill check that today and keep u updated
PostPosted: Wed Jun 18, 2008 5:37 pm
I checked the ground bus on both sides and everything is in place. Im down a power issue is there any common wiring problems to look for.
PostPosted: Wed Jun 18, 2008 5:38 pm
you pulled the metal bar out of the plastic connector?
-Andrew-
PostPosted: Wed Jun 18, 2008 6:36 pm
yes they are fine and intact like i said it is a power issue im not getting power to the switches or the radio there is no problem with the key less entry or the interior lights. where (other than the fuse blocks) can i find a power issue? there is power at both the radio fuse under the steering coloum and the power window breaker under the hood both sides of eaach the fuse and the breaker.have power. i need somthing to go on power wise .. any info please?
PostPosted: Thu Jun 19, 2008 5:45 pm
Year and Trim: 96 SE
if you have 12 v at ip fuse block, it would appear you have a broken wire/bad connection between ip pw relay and pw door switch. probably not a grounding problem since the windows work with power applied directly to switch. if you have ohm meter, test for continuity between ip pw relay and pw switch (pull pw relay first and connect ohm meter to pw side of fuse). if you don't have continuity, chase brown wire from pw door switch back to ip fuse block where visible. you might have to skin brown wire at some point and continue to apply 12 v in sections to isolate the break/poor connection including rubber tubing where wire feeds from body to door.
PostPosted: Thu Jun 19, 2008 11:11 pm
If the master switch in the driver's door is bad, none will work. Pull the master switches, and put a wire jumper (use the schematic above) to bypass one window. Does it work when you use THAT switch with the bypass in the master (drivers) connector? If so, replace the master (drivers) switch.
PostPosted: Fri Jun 20, 2008 12:59 pm
Year and Trim: 1994 SE Bonneville
May I ask you where you got the wire diagram from so that I can get the wire diagram for the hole car.
PostPosted: Sun Jun 22, 2008 12:28 pm
sorry guys i appreciate ur help but turns out it was a fuse. i only checked the obvious fuses before i wrote my post and apperently it was my radio fuse that was blown and causing the problem. who knew the radio would controll power to the PW relay.. well thanks again.. problem solved.
There are no new unread posts for this topic. Help needed fast.
Blownville
Sat Jul 05, 2008 2:00 pm
rcissna View the latest post
There are no new unread posts for this topic. need help fast wont start
trf_ssei
20
2514
Thu Nov 25, 2010 1:36 am
flatlander745 View the latest post
There are no new unread posts for this topic. Fast help please! - Camshaft Position Sensor
mstrwolfgang
Tue Apr 28, 2009 11:02 pm
mstrwolfgang View the latest post
There are no new unread posts for this topic. Fast beeping when a door is open.
Pair of SSEI
Thu Apr 11, 2019 7:01 am
96 SSEi View the latest post
