It is currently Mon Feb 18, 2019 9:01 pm
PostPosted: Thu Aug 05, 2010 10:17 pm
Year and Trim: 1999 Bonneville SE 3.6
Hey guys,
So for a while now my Bonneville has been stalling out at least once a week The rpm's tweak out for a few seconds then it stalls. If I play with the gas before the rpm's drop completely i can keep it from stalling. It happens at any time i can be going 5 or 45 mph, but most of the time it runs fine. Normally it will start right up but occasionally it takes 3 or 4 tries. The engine cranks but just wont turn over. I just had the fuel pump and lines replaced about 6 months ago so I'm pretty sure thats not the problem.
There is also a water leak coming from somewhere that drenches my floor and sometimes back seat. I'm not sure if this can be messing with the electrical or not but is annoying. If anyone can help or has any suggestions please let me know. Thanks, Seth
PostPosted: Thu Aug 05, 2010 10:22 pm
Year and Trim: 2012 Eco
3.6 swap? Caddy CTS motor?
Just kidding! Welcome, and sad to hear that your car's being pissy.
Look at the posts for crank or cam position sensors. That may be your engine problem.
The leak needs its own topic. Check the rear wheel wells for rust. That's a common area to rust out in this generation. My Buick had a good-size hole in the rear passenger wheel well that left the rear floor soaked, and hosed an airbag module. It's fixed now after a couple hundred dollars.
PostPosted: Thu Aug 05, 2010 10:37 pm
Yeah its been doing pretty good except for the past few months. But ill definitely look at those posts and start a new topic for the leak. thanks for the help
PostPosted: Fri Aug 06, 2010 12:34 pm
Year and Trim: 96 SSEi- 157K
This could be a lot of things of course, but my brother's 96 SE was doing the same thing and it was a bad fuel pressure regulator. Do you smell gas?
and again, this could be many things so it's hard to say for sure.
- Rachael
PostPosted: Fri Aug 06, 2010 3:42 pm
Are your battery cables tight and corrosion-free? Are your body and chassis grounds corroded? Those are simple things to check before starting anything else.
PostPosted: Fri Aug 06, 2010 4:23 pm
nope. i dont smell any gas and no dash lights come on its just completely random. i havent checked them yet but im planning to take a look tommoro
There are no new unread posts for this topic. Bonneville wont start?
blademaster
Fri Jul 25, 2008 12:02 am
radomirthegreat View the latest post
There are no new unread posts for this topic. 98 bonneville wont start sometimes
vincet79
Mon Sep 06, 2010 10:09 am
willwren View the latest post
There are no new unread posts for this topic. '92 bonneville error 58 and wont start.
pontiacian
Sat Sep 03, 2011 10:56 pm
There are no new unread posts for this topic. 1995 bonneville wont start and fuel pump relay clicking
zach
Mon Jun 15, 2009 9:50 am
There are no new unread posts for this topic. 1998 SE stalls and wont restart...wait 15 mins it restarts
binarybo
Fri Dec 10, 2010 12:40 am
tgr1957 View the latest post
Users browsing this forum: Google [Bot] and 15 guests
