It is currently Wed Jan 23, 2019 2:48 pm
PostPosted: Tue Jul 20, 2010 1:13 pm
And I've got water sitting on the rear seat shelf. (The interior is out except for the driver seat, shifter, and dash). With no headliner, I've got easy access to the sunroof drains, but they seem to be in place and tight. Where else would allow water to pool on the floor pan shelf under the rear seat? Not the foot well, though. They were dry till I drove and it ran down. If it helps, it was dry after rain yesterday, while it was sitting on flat pavement. But after sitting in the driveway over night with a slight slope (rear end lower), I got water inside.
PostPosted: Tue Jul 20, 2010 1:21 pm
Did you check the common rust spots? I think Bonnevilles likes to rust in the inner wheelweels directly above the rear tires.
PostPosted: Tue Jul 20, 2010 1:35 pm
Door seals will absolutely drop water under the back seat bottom. Happened on my SLE.
PostPosted: Tue Jul 20, 2010 5:14 pm
I pinpointed my leak coming from the seam sealer on the top edge of the trunk opening. Took me a while to find it too.
BonneMe wrote:
PostPosted: Wed Jul 21, 2010 8:16 am
That would be a possibility if there were water in the spare tire well also.
PostPosted: Wed Jul 21, 2010 9:45 am
I'll have to check out the spare later.
PostPosted: Sat Jul 24, 2010 7:02 pm
Year and Trim: '95 Olds Eighty Eight
'94 Olds Silhouette
My 88 has a 4" hole here and water gets under my seat every time it rains.
1994 Caprice Classic LS - 1994 Oldsmobile Silhouette - 1995 Oldsmobile 88 - 1996 Buick Regal
Click here for my Cardomain
PostPosted: Sun Jul 25, 2010 8:32 pm
Year and Trim: 1995 SSei
1987 GN 16K Original
:banana: Have someone go in the trunk and spray with the hose and watch for leaks.
There are no new unread posts for this topic. Car floods in the rain! Help
bongag
Sun Aug 21, 2011 5:41 pm
bongag View the latest post
There are no new unread posts for this topic. Weird sounds during rain
Jfridge92
Sat Jul 04, 2015 10:44 am
There are no new unread posts for this topic. Wet trunk and rear floor after rain
michaelbsc
Sun Aug 07, 2011 10:42 am
willwren View the latest post
There are no new unread posts for this topic. Rain related electrical issue
bad.moshi
Tue Apr 08, 2014 11:14 am
bad.moshi View the latest post
There are no new unread posts for this topic. Whine
blackbeauty99
Fri Feb 28, 2014 9:05 pm
bmoseman View the latest post
