It is currently Thu Feb 21, 2019 2:03 am
PostPosted: Mon Jul 05, 2010 2:50 pm
Year and Trim: 1998 SE
I have access to a 2000 N/A L36 3800 and was trying to make sure that I can put in my 1998 Bonneville wich has the same motor. Any comments, suggestions, or known issues would be appreciated.
PostPosted: Tue Jul 06, 2010 8:59 am
Its the same engine... Bits and pieces will have to be changed over but its the exact same long block
PostPosted: Tue Jul 06, 2010 11:18 am
Thanks, I thought the same thing. Should I use my 98 wiring harness and what items would I change over?
PostPosted: Tue Jul 06, 2010 3:10 pm
You will need
The 98 Harness
The 98 Throttle Body
The 98 Belt Tensioner so that you can use your alternator
You will have to attach your Torque Axis mount to the motor, if you look at the block The bolt hole/s for the Torque Axis mount may be plugged with a Torx Bolt, remove it and install the stud from your other motor...
You may need to use the 98 Exhaust manifolds, but I am not 100% certain on that...
Generally it will be a pretty forward swap
PostPosted: Tue Jul 06, 2010 3:24 pm
Thanks again, I really appreciate it! I am gettin up in years and have always worked on 60's and 70's muscle cars, this newer stuff can be a bit trickier unless you have been doing it for a while.
Any other input on the exhaust manifolds would be appreciated. Have a Great Day! :beerchug:
PostPosted: Tue Jul 06, 2010 3:37 pm
I am thinking that the rear Manifold may be a tad different in exit location to down pipe, but am Not 100% certain..
The only thing I can tell you to do there is to look at both motors, if they look identical in location then you should be good to go..
PostPosted: Tue Jul 06, 2010 4:11 pm
It depends on what the 2000 engine came out of. H-bodies use a different rear manifold than the W-bodies. So if you got the engine from a Grand Prix or Regal you will have to change it.
-Andrew-
PostPosted: Tue Jul 06, 2010 4:47 pm
The motor is from a 2000 Bonneville (H body I believe), so I may not have to change it. I will look at it and measure to insure that is correct though. Thanks!
There are no new unread posts for this topic. Engine Swap Help: 1995 Series II into a 1998
DieselMechanic
36
8536
Thu Feb 16, 2012 10:54 pm
DieselMechanic View the latest post
There are no new unread posts for this topic. 95 Bonneville transmission and / or engine swap
scottauch
Sat Jun 12, 2010 8:53 am
willwren View the latest post
There are no new unread posts for this topic. 1998 Bonnie SSEI Engine Mounts
MrAdamJ15
Wed Mar 15, 2017 1:30 am
95naSTA View the latest post
jjones30
Sat Mar 05, 2011 10:59 am
There are no new unread posts for this topic. Engine swap
lilpon
24
3393
Tue May 08, 2012 6:54 pm
RogueSSEi View the latest post
