It is currently Fri Jul 10, 2020 7:52 am
 Post subject: Bonne won't start
PostPosted: Mon Jun 07, 2010 11:45 pm
Year and Trim: 1993 Bonneville SE
My 93 bonne se won't start. I drove approx 35 miles, turned the ignition off, and about 10 min. later turned key to restart and security light started blinking. I've cleaned batt. connections, swapped with known good battery, moved shift lever from park to neutral, tried spare key. Still won't start. Please help !
 Post subject: Re: Bonne won't start
PostPosted: Mon Jun 07, 2010 11:52 pm
A blinking security light while attempting to start indicates that the security system is not reading the key <differant from reading the wrong key>. Had this happen to mine. I ended up having to bypass the system with resistors. Either the connectors broke in the column, wire broke going to the dash, etc.
This bailed me out:
http://vats.likeabigdog.com/
The correct way to fix it, of course, is to track down the failed part, and replace it, but good luck with that :twisted:
PostPosted: Mon Jun 07, 2010 11:55 pm
Year and Trim: before cars
Likely cause is a bad ignition lock cylinder. The tiny wires for the security system tend to break off of the lock cylinder after so many years/lock cylinder rotations. If that is the cause, it can be bypassed for about $1 with a radio shack resistor of the propper resistance and some carefull soldering.
PostPosted: Fri Jun 11, 2010 4:41 am
Sorry for the delayed response. Been very busy. Just want to thank all for their suggestions. (rjolly87,1fatcat,etc...) bonne's rollin' again. The resistor mod. got me going. This weekend I'll check lock cylinder and wiring to see which is the culprit. Thanks again !!!!!
There are no new unread posts for this topic. 96 Bonne SE outta gas and now won't start
96se
21
2512
Thu Apr 23, 2009 9:01 pm
96se View the latest post
There are no new unread posts for this topic. 96 Bonne - Hard to start when engine hot,
jmulhearn
Tue Aug 27, 2013 3:38 pm
95se View the latest post
There are no new unread posts for this topic. 98 bonne SSEi won't start/turnover
dougbee
Sun Apr 17, 2016 7:46 pm
MKMike View the latest post
There are no new unread posts for this topic. Rough start/poor idle on cold start
gk35
Sun Nov 10, 2019 9:03 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 95 bonne sse problems
Marshall2469
Sun Jan 30, 2011 2:55 pm
Marshall2469 View the latest post
